Old 09-22-2020, 10:26 AM
Roy Roy is offline
Adding a lot of Avatars
How to add many avatars at once?
If we try to add 100 different avatars, do we need to use 'addAvatar()' for each avatar?
Old 09-25-2020, 01:22 PM
You can note it all down in a list and iterate through it. Here's a sample script for it.
viz.clearcolor(viz.SKYBLUE)
avatar_files = ['vcc_male.cfg', 'vcc_female.cfg', 'vcc_male2.cfg']
avatars = []
position = 0
for i in avatar_files:
new = viz.addAvatar(i, pos = (position*2, 0, 4), euler=(180,0,0))
avatars.append(new)
position += 1
Old 09-26-2020, 11:34 AM
Roy Roy is offline
Hi Sado,
How about animations for each avatar?
If animation is added by 'state()', do every avatars have different animations?
I tried to make 2avatars x 15 animations list, and show them in random order as program below. But the same avatar with same animation is shown.
avatar_files = ['vcc_male.cfg', 'vcc_female.cfg']#2avatars
animation = range(1,16)#default 15 animations
#make 30 stimuli list (2avatars x 15animations), and shuffule the order
stimulus = []
	for j in animation:
		avatarAnim = viz.addAvatar(i, pos=(0,0,0), euler=(180,0,0))
		avatarAnim.state(j)
		avatarAnim.visible(viz.OFF)
		stimulus.append(avatarAnim)
random.shuffle(stimulus)
def experiment():
	yield viztask.waitKeyDown(viz.KEY_RETURN)
	for trial in stimulus:
		yield viztask.waitTime(1)
		avatarAnim.visible(viz.ON)
viztask.schedule(experiment())
Old 09-28-2020, 11:54 PM
kennethkarthik kennethkarthik is offline
Moderator
Hi Roy,
There was just a bug in your code. You were setting "avatarAnim" to visible off and on states in your experiment function instead of using "trial" which would iterate between your shuffled states.
import random
import viztask
animation = range(0,16)  #default 15 animations
piazza = viz.addChild('piazza.osgb')
#make 30 stimuli list (2 avatars x 15 animations), and shuffle the order
stimulus = []
	for j in animation:
		avatarAnim.state(j)
print(stimulus)
print(stimulus)
def experiment():
		trial.visible(viz.ON)
		trial.visible(viz.OFF)
Check this and let us know if this was your intended experiment. Thanks
Old 10-04-2020, 02:36 AM
Roy Roy is offline
Hi kennethkarthik,
Thank you, it works!
But I'm wondering any other way to add avatars.
In this program, 2 avatars are loaded 15 times, causing long time to run the program.
Any ideas?
Old 10-05-2020, 03:41 PM
Moderator
Hey Roy,
Vizard does it's optimisation when it reuses objects. However if you do want to improve load time, I would suggest just changing the state of your characters on the same avatar instead of adding a new one for each animation state. Check out the code below
import random
import viztask
avatars = []
	avatars.append(avatarAnim)
def experiment():
	for i in avatars:
		i.visible(viz.ON)
		for state in animation:
			yield viztask.waitTime(0.5)
			i.state(state)
		i.visible(viz.OFF)
avatars, avatars animation
Regarding the visibility of avatars SivaKartheek Vizard 2 01-13-2016 07:48 AM
avatars dig Vizard 4 09-20-2007 03:29 PM
adding heads to custom avatars vAlexia Vizard 5 02-13-2007 11:14 AM
Avatars in an array and link/unlink betancourtb82 Vizard 7 09-05-2006 04:06 PM
