Old 08-03-2016, 02:10 PM
Ryan Choi Ryan Choi is offline
Exclamation UDP connection error
I am trying to integrate a motion capture system into Vizard. The capture software broadcasts its data through a UDP port(7001 by default); however, Vizard produces this error when the script runs :
ERROR: VizReceive::init() failed to bind socket to local port (UNKNOWN)
I used the command prompt to make sure the port was being accessed by the capture software and it was. Also, I ran the program on another computer to check if the error was system based, which it wasn't. Maybe using TCP would help, but I couldn't find sufficient documentation on that.
Here's the section of the script where the error probably originates from:
from Euler2Quat import *
class PerceptionNeuron:
def __init__(self):
self.avatar = None
self.mode = None
self.sample_frame = list(range(180))
self.oculus_tracker = None
self.offsetPos = [0,0,0]
self.offsetEuler = [0,0,0]
def connectUDP(self):
myNetwork = viz.addNetwork('127.0.0.1')
viz.net.addPort(7001)
viz.net.removePort(4950)
def connectAvatar(self,avatar):
self.avatar = avatar
def connectOculus(self,oculus_tracker):
self.oculus_tracker = oculus_tracker
def setMode(self,mode):
self.mode = mode.lower()
def setOffset(self,offset):
self.offsetPos = offset[0:3]
self.offsetEuler = offset[3:6]
def onNetwork(self,e):
if isinstance(e,viz.RawNetworkEvent):
print e.raw_data
ord_data = list(range(len(e.raw_data)))
chr_data = list(range(len(e.raw_data)))
space_index = []
for i in range(0,len(e.raw_data)-1):
ord_data[i] = ord(e.raw_data[i])
chr_data[i] = chr(ord_data[i])
if ord_data[i]==32:
space_index.append(i)
if ("".join(chr_data[0:8])!='0 Char00'):
raise ValueError('wrong header')
for i in range(0,179):
sample_frame[i] = float("".join(chr_data[space_index[i+1]+1:space_index[i+2]]))
self.sample_frame = sample_frame
linkBVHtoAvatar(sample_frame,self)
def startCallback(self):
viz.callback(viz.NETWORK_EVENT,self.onNetwork)
def connectViewpoint(self,view=viz.MainView):
headLink = viz.link(self.avatar.getBone('Bip01 Head'),view)
vizact.onupdate(viz.PRIORITY_PLUGINS+2,headLink.up date)
if self.mode.find('oculus')!=-1 and self.mode.find('ppt')!=-1:
headLink.preTrans([0,0.3,0.2])
headLink.preTrans([0,0.15,0.1])
Old 08-05-2016, 08:26 AM
Did you try running this Vizard script on a different machine than the Perception Neuron server? It maybe an issue related to using the loopback address.
Old 08-09-2016, 11:51 AM
No, I did not, I'll try that. Thanks
vicon.dle error deuce168 Vizard 2 06-03-2015 07:49 AM
Debugger error messages in Vizard 5 mape2k Vizard 1 12-09-2014 07:02 AM
Polhemus FasTrak Error Message JB_HP_Viz Vizard 4 08-15-2014 10:32 AM
Error using CMF export from 3ds max to cal3d in some avatars disbeat Vizard 4 04-16-2014 12:40 AM
Polhemus Liberty Latus connecting error Yang Vizard 2 02-13-2013 12:52 PM
