Old 03-23-2012, 09:01 AM
hotshotiguana hotshotiguana is offline
Publish to exe Script
I am trying to create new versions of my software on the fly - currently the software is only available on the desktop. For example, I want to have the capability for a user to select certain parameters on our website and then have a new version created for them with those specified parameters. Is it possible to run the "File-->Publish as EXE" command from a script to create a new executable of our software? If not, does anyone have any suggestions on how to go about this?
Chris
Old 03-23-2012, 11:41 AM
Yes, this should be possible. Here are the steps you need to follow:
  • Go through the standard "Publish to EXE" workflow.
  • On the "Finished Publishing" dialog at the end, save the publish settings by clicking on the "click here" link. This should save the publish settings file to your script folder.
  • You can now automatically generate the exe using the settings file through the following command line:
    Vizard.exe -publish "<full path to the publish settings file>"
    This should create an exe in the same folder as the settings file with the same filename. For example, if your settings file was located at "C:\MyScript\MyDemo.xml", the EXE would be located at "C:\MyScript\MyDemo.exe".
Old 03-26-2012, 01:54 PM
Thanks for the response!
Old 01-29-2013, 01:00 PM
Adam.Grey Adam.Grey is offline
I attempted to use vizard.exe -publish, and it just launches vizard. Has this feature been removed?
Old 01-29-2013, 03:42 PM
Try specifying the path to the vizard.exe in the bin folder:
"C:\Program Files (x86)\WorldViz\Vizard4\bin\vizard.exe" -publish "C:\MyScript\MyDemo.xml"
Old 01-31-2013, 02:30 PM
Gave that a shot, no luck. If it finds the file and begins publishing but runs into an error, will it report back in any way? Should I reroute stderr?
Old 01-31-2013, 06:08 PM
When you publish the first time from the Vizard GUI is there any problem?
Old 12-22-2015, 11:34 AM
meltaweel meltaweel is offline
Registered User
Hello ,
it's an old topic , but i have the same problem as Adam.
i'm using Vizard 5 and i tried to do this as explained above
"C:\Program Files (x86)\WorldViz\Vizard5\bin\vizard.exe" -publish "C:\Users\USERNAME\Desktop\SETTINGS_FILE.xml”
it doesn't show up with any thing and the exe file doesn't be generated beside the XML file as Jeff said.
and yes when i have published first time from Vizard GUI , it published the exe without any problems and was working fine. and i've used the "publish settings" XML file from the "Finished Building" step.
and i have ensured that the bin file path working fine because when i run
"C:\Program Files (x86)\WorldViz\Vizard5\bin\vizard.exe" this it opens the Vizard IDE successfully !
please help !
exe, on the fly, publish
starting Vizard from a Python script hotspur1 Vizard 12 06-12-2019 01:03 PM
Simplest script not working vasiliys Vizard 2 10-25-2011 11:24 AM
script file available - but missing spdegabrielle Vizard 1 05-06-2009 11:04 AM
Publish EXE with win32com djdesmangles Vizard 7 08-13-2008 04:49 PM
Intersense Script wouters Vizard 2 04-07-2008 01:59 PM
