Old 04-14-2015, 05:58 AM
vrtheater vrtheater is offline
Registered User
Importing constraints
Hi there,
I have rigged an robot in blender with armatures, bones and constraints.
I exported the result into fbx format (afaik it should include constraints) and converted the fbx file to osgb using this code:
target = viz.add('robot_constraints.fbx')
target.save('robot_constraints.osgb')
two questions:
a) does the information about constraints persist the conversion?
b) how do I address those bones?
I tried this:
robot = viz.add("robot_constraints.osgb")
robot.getBones("bone1")
Which does not work because robot does not have the attribute getBones()
"AttributeError: 'VizChild' object has no attribute 'getBone'"
Using getChild("bone1") does not help me either or at least I am unsure what to do with it.
Could you give me some hints how to get to the bones itself?
Old 04-15-2015, 05:46 AM
mape2k mape2k is offline
I cannot answer question a, but question b is solved by using <robot.getChild('name of handle')>.
The reason why <getChild()> did not work for you is probably because you specified a wrong handle name. To find out the exact handle names, you can access the osgb model with the Vizard Inspector. There you will find the model and all its sub-parts.
You can upload the model here if you want, that would make it easier for me to see what the problem is.
Best,
Johannes
IK Handles and LookAt Constraints from Max EnvisMJ Vizard 1 02-24-2011 05:55 PM
Problems Importing Large wrl files? viz_kix Vizard 2 03-12-2008 06:31 PM
Importing other moduels v-Salik Vizard 1 10-15-2007 07:18 AM
Importing from Blender and getting "real" sizes for models? tmcw Vizard 1 03-19-2007 10:37 AM
importing a single WRL with many objects. giancamati Vizard 3 12-18-2006 02:13 PM
