Old 10-09-2014, 07:03 AM
BSUGeek BSUGeek is offline
Question Vizard export to xml file
I'm creating a program that receives the data from the timer and the avatar position. I was wondering is there a way to export that data into an xml file and change the timer format to output MM:SS instead of seconds and milliseconds? and for the avatar can you just get the X position instead of the full x,y,z position?
Old 10-10-2014, 04:00 PM
You could search online to see if there is a Python add-on library that writes data to an XML file. The string formatting page in the Vizard help shows examples of formatting in Python. The following code returns the first value (X position) in the position list:
x_pos = avatar.getPosition()[0]
Vizard .exe file doesn't load (Vizard 3) Saule Vizard 4 02-05-2014 07:01 AM
Interaction of vizard objects with an imported obj file sunil.nair Vizard 2 10-09-2013 03:08 PM
Export from 3Ds Max to Vizard pattie Vizard 5 08-26-2006 12:20 PM
female skeleton CSF file needed to export to CAF format vmonkey Vizard 1 10-04-2005 11:15 AM
