Old 05-14-2014, 05:35 AM
Transparency issues in Viz5?
Here is a snippet of code that produces different results in Viz4 and Viz5.
It works correctly in Viz4, producing a semi-opaque green box with 1 red side. In Viz5, it produces a black box (no transparency).
self.standingBox = vizshape.addBox( boxSizeInfo,alpha = 0.7,color=viz.GREEN,splitFaces = True,back=True)
self.standingBox.disable(viz.CULL_FACE)
Old 05-16-2014, 08:29 AM
Can you post a working example that shows the issue? I think some of your code is not showing up properly because of using the quote tags. Try using the code tags instead.
I'm not exactly sure what the issue you are seeing is. In Vizard 5, I've noticed if the alpha is set when creating the box the face set to red afterwards does not have the same alpha value as the rest of the box. To workaround this you can set the alpha later in the code:
import vizshape
import vizcam
standingBox = vizshape.addBox(size=[1,1,1],color=viz.GREEN,splitFaces = True,back=True)
standingBox.color(1,0,0,node='back')
standingBox.alpha(0.6)
vizcam.PivotNavigate()
transparency control hankiwan Vizard 1 02-14-2012 07:02 AM
How to vary the transparency of the scene whj Vizard 2 04-04-2010 08:16 PM
Transparency on multiple objects NASA GRC Vizard 0 03-15-2010 12:46 PM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 02:16 PM
Quicktime movie with transparency channel aaThomas Vizard 7 11-12-2007 09:54 AM
