Old 02-18-2014, 09:13 AM
Powell Powell is offline
Vizard with Tobii eye trackers
I am keen to integrate a Tobii 2x-60 eye tracker with Vizard. At the moment I don't need to do anything too clever (e.g. gaze contingency) just monitor fixation and see whether certain responses of the viewer are associated with particular eye movement patterns. Tobii provides a SDK for Python but on their website they say that this has not been tested with Vizard.
Is anyone know if it is possible to integrate a Tobii with Vizard and if so, how this might be done? I am fairly new to python programming although have worked more extensively with matlab + eyetracking.
I am running Windows 7 64bit if this is useful.
Many thanks in advance,
Georgie
Old 02-28-2014, 06:25 AM
Do you have an example python script that shows how to get the tracker data? If so, you could call the same python commands in a Vizard function that gets called every frame.
problem in using xsens motion trackers in Vizard bharatbhushan Vizard 3 01-26-2009 06:51 PM
