Old 02-17-2014, 04:15 PM
TopazFrost TopazFrost is offline
How do I get the Cave viewpoint location?
I have another question about CAVE collision. I am using cView = vizcave.CaveView(...) for the view point.
I have one last collision problem. When going backward down a hill/stairs, the view point likes to get trapped underneath the hill/stairs. I think I can correct for it if I can get cView's Y value, but cView.getPosition() returns the joystick position or [0,0,0]. What is the call/mask needed to get the cView position?
I can't set the viz.eyeheight() any higher since I am already having trouble with colliding with the tops of doorways (which are at 2m).
Old 02-18-2014, 12:51 PM
One more item. I am getting a collision error from vizard, that I have no idea how to handle. It only happens when moving quickly through a opening vizAvatar door. It is:
File "<string>", line 1
    viz.VizIntersect([1,23.610281,0.621243,-17.971189,-0.876875,-0.000000,0.480718,399,-1.#QNAN0,''])
SyntaxError: unexpected EOF while parsing
Old 02-20-2014, 06:23 AM
The following code showed the cave view position updates when added to the example script in Vizard's CAVE documentation:
def printPosition():
	print cave_origin.getPosition()
vizact.ontimer(1,printPosition)
Have you linked or parented the cave view to another object?
Old 02-20-2014, 11:03 AM
I have not. Doing so made the view spin or froze the view point.
The bigger problem right now is the intersection error. How do I catch it so it does not crash the program?
Old 02-20-2014, 11:41 AM
I forgot...I am assuming that cave-origin is the cave's view point returned by vizcave.CaveView(...). That works correct until I collide with a wall, then it keeps going while the viewpoint stays still.
I have not linked it other than giving it a tracker.
Old 02-20-2014, 07:18 PM
Update on collision error. I happens when hitting a vizAvatar even when going slow and have it running on the HMD, but not all vizAvatar. It went away (I hope) after I removed the collision event handler. That is a problem since I need it for the CAVE.
Intermittent orthographic stereo projection problems AySz88 Vizard 10 02-17-2012 01:50 PM
[New here] Cave joy navigation esuna114 Vizard 2 06-11-2010 05:36 PM
Flipped floor in a CAVE shivanangel Vizard 1 03-10-2010 11:12 AM
Gps input for viewpoint location? realvision Vizard 3 03-19-2008 01:37 PM
VRML Viewpoint error bstankie Vizard 1 03-11-2003 03:10 PM
