Old 12-10-2013, 10:34 AM
white white is offline
easeout wheel-rotation
How can I ease out a wheel-rotation depending on another action (motion of car)? I could rotate the wheel and easeout the rotation.
rim1.setCenter([1.5,0.32,0.945])
spinAction = vizact.spin(-1,0,0,270,10)
rim1.addAction(spinAction)
yield viztask.waitActionEnd(rim1,spinAction)
easeOut = vizact.spinTo(axisAngle=[1,0,0,0],speed=120, interpolate = vizact.easeOut)
rim1.addAction(easeOut)
But now I'd like the end of rotation to fit the time the cars stop. The cars have different starting positions (and therefore do not always take the same time to get to the stopping point), move to one point and ease out as well.
action1 = vizact.moveTo([-2,0,2],speed=13.89, interpolate=vizact.easeOut)
How can I link these two actions?
Thank you.
Gerda
Old 01-02-2014, 10:37 AM
wheel rotation
Hi there,
I'm still struggeling with the posted question...
Maybe it's possible to stop the two actions at the same time with the "viz.ANIMATION_END_EVENT" command ?
thanks for helping
Old 01-03-2014, 01:37 AM
I think this should fix your problem:
import viztask
viz.eyeheight(0)
viz.MainView.setPosition(0,0,-4)
car1 = viz.add('box.wrl')
rim1 = viz.add('box.wrl', color = [0,0,1])
car2 = viz.add('box.wrl', color = [1,0,1])
rim2 = viz.add('box.wrl', color = [0,1,0])
action1 = vizact.spin(0,0,1,60)
action2 = vizact.moveTo([-2,0,2],speed=2.00, interpolate=vizact.easeOut)
action3 = vizact.moveTo([-2,0,2],speed=4.00, interpolate=vizact.easeOut)
def actionTime():
	rim1.addAction(action1,0)
	rim2.addAction(action1,0)
	car1.addAction(action2,0)
	car2.addAction(action3,0)
vizact.onkeydown(' ', actionTime)
def onActionEnd(e):
	if e.object is car1:
		rim1.endAction(0)
	elif e.object is car2:
		rim2.endAction(0)
viz.callback(viz.ACTION_END_EVENT,onActionEnd)
In this example, the green box (rim2) is the rim of the purple box (car2), and the blue box (rim1) is the rim of the red box (car1). The red and purple box arrive at different times at the end position, and the rotation of their rims stop accordingly. Replace the boxes with your appropriate models, and you should be good to go!
Last edited by Frank Verberne; 01-03-2014 at 01:43 AM. Reason: improved readability of code
Old 01-06-2014, 07:17 AM
Erikvdb Erikvdb is offline
Frank, that only starts/stops the spinning, it doesn't ease-in or out.
I think a more flexible solution would be to wire -in 3ds max terms- the wheel rotation to the car translation. I can't really remember how it works best exactly, but here's a quick and dirty version, based on Frank's code:
import vizmat
carPos = car1.getPosition()
viz.eyeheight(0)
viz.MainView.setPosition(-5,0,-20)
action1 = vizact.moveTo([-10,0,0],speed=4.00, interpolate=vizact.easeInOut)
def actionTime():
	car1.addAction(action1,0)
def onUpdate():
	global carPos
	newPos = car1.getPosition()
	distance = vizmat.Distance(carPos,newPos)
	rotation = distance * viz.getFrameElapsed() * 2000
	car1.setEuler([0,0,rotation],viz.REL_LOCAL)
	carPos = newPos
vizact.onupdate(0, onUpdate)
The 2000 number should be based on the wheel circumference, but I forgot how it relates exactly, so it's just an arbitrary multiplier.
car wheel rotation
Steering wheel mini Biom Vizard 2 06-17-2013 11:53 PM
Custom Joystick Rotation mhead10 Vizard 9 11-26-2012 12:06 PM
Changing Force-feedback on Wheel Cage Vizard 3 10-23-2010 08:37 AM
set bone rotation - cal3d munteanu24d Vizard 0 03-23-2010 04:25 AM
Unable to perform 360 rotation using vizact.spinto vijaykiran Vizard 2 09-29-2009 08:39 AM
