Old 07-09-2013, 05:01 AM
CompSci CompSci is offline
Panel Dimensions
Does anyone know how to create a panel with fixed dimensions? How do I set the panel dimensions?
Old 07-09-2013, 09:39 AM
Are you referring to a vizdlg.Panel object? If so, the panel size will not change when the window is resized. The size of the panel is determined by the fontSize and other parameters such as spacing and margin.
Old 07-09-2013, 10:04 AM
Ok, so the size of the panel is determined by the elements that are added?
Old 07-10-2013, 10:11 AM
Yes, the panel adjusts its size to account for all the elements.
Old 07-11-2013, 07:39 AM
Thanks!
one panel over all windows Andy Vizard 5 04-11-2012 09:24 AM
Problem Vizdlg panel draw order Chapre Vizard 1 05-17-2011 02:29 PM
vizdlg Panel: Add and remove disbeat Vizard 2 02-08-2011 12:44 PM
vizdlg dialog components on a single panel Chapre Vizard 3 11-20-2010 02:47 PM
Setting Collidebox Dimensions vTony Vizard 2 09-29-2009 02:57 PM
