Old 02-15-2012, 09:30 AM
Andy Andy is offline
geometryshader parameters
I want to use a simple geometry shader. How can I set the GEOMETRY_INPUT_TYPE_ARB, GL_GEOMETRY_OUTPUT_TYPE_ARB and GL_GEOMETRY_VERTICES_OUT_ARB parameters?
#version 120
#extension GL_ARB_geometry_shader4 : enable
//input GL_TRIANGLES
//output GL_LINE_STRIP
varying in vec4 V[3];
varying in vec3 N[3];
uniform float nLength;
void createNormal( vec3 V, vec3 N )
    gl_Position = gl_ModelViewProjectionMatrix * vec4( V, 1.0f );
    EmitVertex();
    gl_Position = gl_ModelViewProjectionMatrix * vec4( V + N * nLength, 1.0f );
    EmitVertex();
    EndPrimitive();
void main()
    for ( int i = 0; i < 3; ++i )
        createNormal( V[i].xyz, N[i] );
Any idear?
Old 02-15-2012, 09:34 AM
You should be able to use the layout modifier in your geometry shader source to specify these parameters. Example:
#version 330 compatibility
layout(triangles) in;
layout(triangle_strip, max_vertices=3) out;
Old 02-21-2012, 07:21 AM
thanks, it works
OSG Text Node Additional Parameters pcatalano Vizard 2 11-01-2011 08:45 AM
Question about serial port mizutani_jun Plug-in development 6 11-21-2010 04:53 PM
Reading in parameters with a published exe Jerry Vizard 1 03-03-2008 10:46 AM
