Old 10-11-2010, 02:01 AM
mizutani_jun mizutani_jun is offline
Unhappy Use saved text file data as replay sources problem
Hi.
I got problem using my saved data text file data as replay sources.
I took data from patriot as euler data and keyboard as my position data,and save this all in difference text file.
From this data,i want to make replay but i got some errors about strings.
I previously using matlab as my main sources and no problem using strings to make calculations but seems i cant do same thins in vizard.
Below is my commands.
openfile1=open('filename1.txt')
nposz=[]
for line in openfile1:
s=line.split()
nposz.append(s[0])
x=nposz[0]
y=nposz[162]
print x - y
I try to make easy calculation like above and this errors written in input/output window.
File "<string>", line 11, in ?
File "add_replay.py", line 217, in ?
print x - y
TypeError: unsupported operand type(s) for -: 'str' and 'str'
My question is how can i make calculation with this text data?
How can i use this data other than call it as strings?
I want to calculate the difference in every frame and use it as sources for my replay sources as below.
def replay(num):
n=0
while n<=162:
xposz=nposz[n+1]-nposz[n]
pos=viz.MainView.getPosition()
replay_data_pos=viz.MainView.setPosition(-44,1.8,pos(0)+xposz)
viz.callback(viz.TIMER_EVENT,replay)
viz.starttimer(0,.1,viz.FOREVER)
I dont want to make calculation in real time and i want to save in text data because want to use this data in future.
Is there some sources that i can read or explanations that i missed?
Really need help.
Thanks.
Old 10-11-2010, 10:16 AM
masaki masaki is offline
You need to convert your string data to int or float:
e.g.
nposz.append(float(s[0]))
Masaki
Old 10-12-2010, 01:51 AM
Thanks for the reply Masaki.
Yes it seems this is the function that i missed.
Thanks a lot.
Is there any sources or details i can read about calculation or related to this?
For now i searched just from this forum but it really great if someone can tell me the way to check all this command or function.
So i can study by myself and just asking when i not understand.
MJ
Old 10-12-2010, 10:17 AM
The Python scripting language is open source so there is a ton of resources online. Vizard 3.0 uses Python 2.4. http://www.python.org/
Python and Vizard help docs are also included with Vizard, along with demos, tutorials, and examples. You might also want to also take a look at our "Teacher in a Book" - this is available from our downloads page.
Masaki
Old 10-14-2010, 05:49 PM
I already read all sections in "Teacher in a Book".
And from now i`ll take a look at resources online as my references.
Thanks again.
MJ
still problem with data from .exe file Saz Vizard 1 07-10-2009 11:12 AM
problems with output to a text file within executable Saz Vizard 1 07-01-2009 12:01 PM
writing joystick position to a data file Saz Vizard 3 12-17-2008 06:18 AM
Problem generating exe file Anfo Vizard 1 11-17-2008 05:21 PM
Flagging the Data Elittdogg Vizard 5 04-11-2008 12:40 PM
