Old 02-15-2010, 02:17 PM
llqqff llqqff is offline
question on linking markers in Vicon
Hi, I know vizard can link the vicon marker to some object like:
#Add a vicon marker
marker = viz.add('vicon.dls')
#Add a 3d ball to represent the marker
ball = viz.add('white_ball.wrl')
#Link the 3d ball to the marker
ball.link(marker)
Then is it possible to link a set of markers into vizard? Now I have vicon motion capture system and we capture human's movement. there are 53 markers in total for a subject, is it able to connect these markers to an avatar in Vizard directly? I know I can use live character. Thanks.
Old 02-16-2010, 06:20 PM
For motion capture our solution uses Motionbuilder to get the motion capture data, perform the inverse kinematics and map that to a skeleton and the Live Characters plug-in to stream the skeleton data into Vizard.
Old 04-09-2010, 05:38 AM
Moh200jo Moh200jo is offline
I am aware if I need to use Vizard's avatar i have to use the livecharcater, but if I can export a skeleton from 3dsmax how can link the makers to the 3dsmax skeleton?
is there any way can be used to control avatar through Vicon and Vizard without livecharcater?
Old 04-12-2010, 06:32 PM
Mojo,
You can access the Vicon data through Vizard's Vicon plug-in.
It is possible to animate an avatar with a tequniqe know as inverse kinematics. Inverse kinematic maps Vicon points to avatar bone rotations.
This is a hard problem. Seach inverse kinematics in google for resources.
Old 04-13-2010, 06:23 AM
HI Paul,
Thanks for your post. I know the solution would be the IK and it is a hard way if I choose. is there any possibility to use PyKDL package?
Old 04-13-2010, 10:36 AM
KDL looks cool! Defintaly a possible solution for you.
Keep us updated =), would love to see how your experence with KDL is.
sensor linking question smith11235 Vizard 6 05-31-2011 05:58 PM
vicon pluglin - cluster problems Andy Vizard 2 11-10-2009 02:04 AM
Linking and Intersense Question durf Vizard 1 07-23-2009 11:09 AM
Vicon plug-in dudey12 Plug-in development 11 04-25-2008 09:59 AM
General question and question regarding arrays dan12345 Vizard 1 01-15-2008 11:15 AM
