Old 02-14-2012, 01:53 PM
EnvisMJ EnvisMJ is offline
Identify a class via its mesh
So I've been having a problem for a while, I need to identify a class object via the 3D mesh that represents it in the environment.
Example code:
#Sample Environment
ground.tag = "You missed clicking on a box."
class exampleObject(object):	#Example class containing a mesh
	def __init__(self,classTag,geometryTag,x,y,z,color):
		self.tag = classTag
		self.model = viz.add('box.wrl')
		self.model.tag = geometryTag
		self.model.setPosition(x,y,z)
		self.model.color(color)
		self.model.setScale(.333,.333,.333)
#Creating some objects
A = exampleObject("classA","geometryA",-.5,1.6,2,viz.RED)
B = exampleObject("classB","geometryB",0,1.6,2,viz.BLUE)
C = exampleObject("classC","geometryC",.5,1.6,2,viz.GREEN)
def clickPick():	#Pick an object
	mesh = viz.pick()
	classObject = mesh  ###This line should be modified###
	print classObject.tag
vizact.onmousedown(viz.MOUSEBUTTON_LEFT, clickPick)	#Pick an object on Left-click
#The problem, how do I go from the mesh to the class object...
#As in what (function) do I need to apply to the [mesh] to return the [class object]
#Example:
def classPick():	#Pick an object, print it's class' tag
	mesh = viz.pick()
	classObject = mesh.(function)()
#Should print "classA" rather than "geometryA"
#Should print "classB" rather than "geometryB"
#Should print "classC" rather than "geometryC"
How do I get it to return the class object rather than the geometry?
Old 02-15-2012, 08:43 AM
If you have your exampleObject class inherit from the Vizard node class, then your class instance will be returned from the pick command. I modified your example to show this:
#Sample Environment
class exampleObject(viz.VizNode):	#Example class containing a mesh
		viz.VizNode.__init__(self,model.id)
		self.class_tag = classTag
		self.geometry_tag = geometryTag
		self.setPosition(x,y,z)
		self.color(color)
		self.setScale(.333,.333,.333)
	def printTag(self):
		print self.class_tag,self.geometry_tag
	mesh = viz.pick()
	if isinstance(mesh,exampleObject):
		mesh.printTag()
class, mesh, object, pick
Jumping to a class object from one of it's components EnvisMJ Vizard 0 04-25-2011 11:22 AM
Collide mesh on child objects Enlil Vizard 1 08-31-2010 05:52 PM
Multiple Mesh Avatar Texturing v-jbinney Vizard 6 11-13-2007 11:00 AM
changing the texture of an avatars shirt/body bailenson Vizard 19 05-04-2006 10:00 AM
method of a class instance not accepted as Callback Gilliard Vizard 1 08-10-2005 05:49 PM
