Old 11-20-2009, 03:13 AM
Rik Rik is offline
Problem connecting dataglove
I am trying to connect an Intersense 5DT glove. It works fine when I connect it within the main file of my program, but when I try to connect it in a different python module I always get an error. Of course I could just put the code in my main module, but I have a thing for keeping things nice and tidy.
Here is some sample code to illustrate my problem:
#file glovetest1.py
#this works fine when I run it in vizard
import hand
PORT_5DT_USB = 0
sensor = viz.add('5dt.dls')
glove = hand.add(sensor,hand.GLOVE_5DT)
viz.MainView.translate(0,0.02,-0.4)
#file glovetest2.py
#this does not work
import glovetest
The output on the console when I run glovetest1.py:
** Loading glovetest1.py
5dt.dls 5DT Glove Driver v1.0
** NOTIFY: Connected to 5DT DG5 Ultra USB on USB0
Loading File: hand.cfg
** Load Time: 0.38 seconds
And when I run glovetest2:
** Loading glovetest2.py
** ERROR: Failed to connect to 5DT glove on COM1
** Load Time: 3.85 seconds
Can anyone help me with this problem? Thanks!
Old 12-08-2009, 05:34 PM
In your code that works it looks like you are connecting to the glove over USB but in the one with an error Vizard is looking for a glove over the serial connection. What if you specify a USB port in the module you import?
Vertex shader performance problem Joran Vizard 2 11-17-2008 01:29 AM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
problem with female animations vmonkey Vizard 1 10-07-2005 10:36 AM
sound problem alaa Vizard 7 09-02-2005 01:13 PM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 04:22 PM
