Old 09-27-2009, 12:14 PM
vTony vTony is offline
Setting Collidebox Dimensions
Hello, I am trying to manually set the dimensions of an object's collidebox. As a simple test, I tried setting the dimensions of the collidebox to the size of the object's bounding box. This works for box.wrl, but with the file tree.3ds (located at https://www.stanford.edu/~tony516/tree.3DS), I get strange results. The tree on the left (which uses the default arguments for collidebox, behaves normally, but the tree on the right shoots up into the air.
import viz, vizact
def setOnGround(obj):
ymin = obj.getBoundingBox().ymin
pos = obj.getPosition()
obj.setPosition(pos[0], pos[1]-ymin, pos[2])
def enablePhysics():
viz.phys.enable()
ground.collidePlane()
tree1.collidebox()
tree2.collidebox(tree2.getBoundingBox())
viz.clearcolor(viz.SKYBLUE)
viz.MainView.move(0,0,-15)
tree1 = viz.add('tree.3ds')
tree2 = viz.add('tree.3ds')
tree1.scale([.2]*3)
tree2.scale([.2]*3)
tree1.setPosition(-10, 0, 15)
tree2.setPosition(10, 0, 15)
setOnGround(tree1)
setOnGround(tree2)
vizact.onkeydown('1', enablePhysics)
Thanks in advance for any help!
Old 09-28-2009, 04:19 PM
Please use the [code][/code] tags when posting code. It will preserve indentation which is necessary for running Python code.
Regarding your question, you need to reset the position of the tree before retrieving it's bounding box. Here is a modified version of your code:
import viz, vizact
	viz.phys.enable()
	tree1.collidebox()
	#Zero position before retrieving bounding box
	pos = tree2.getPosition()
	tree2.setPosition(0,0,0)
	#Get objects bounding box
	bb = tree2.getBoundingBox()
	#Restore position
	tree2.setPosition(pos)
	#Use bounding box for collision
	tree2.collidebox(bb.size,pos=bb.center)
tree1.scale([.2]*3)
tree2.scale([.2]*3)
setOnGround(tree1)
setOnGround(tree2)
Old 09-29-2009, 02:57 PM
That fixed it. Thanks!
Tiling in a cluster setting vijaykiran Vizard 5 10-30-2009 11:41 AM
problem in setting the orientation of bones bharatbhushan Vizard 0 06-30-2009 04:30 AM
error while setting material properties. Chandan Vizard 1 10-25-2006 09:31 AM
Setting the viewpoint with tracking VAmanda Vizard 3 10-26-2005 02:02 PM
Setting up a 'reaction area' Karthi Vizard 4 01-29-2004 04:39 PM
