Old 01-26-2011, 08:13 AM
knightgba knightgba is offline
Lighting relevant text?
Hi, guys
I am trying to implement a lighting relevant text effect but not quite sure
Basically the "lighting relevant text means" the text's color is be decided by the lights in the scene depends on the text's orientation (Assume the text spins)
L1 L3
Text(Spins)
L2 L4
My idea is giving different ambient values to the text based on calculating the orientation value(use text.getAlignment?) of the text node every frame.
Appreciate any advice, cheers
Old 01-26-2011, 06:33 PM
You could use the getEuler() command to get the orientation of the text object every frame.
basic lighting question malte Vizard 6 12-01-2010 01:25 PM
Informationboxes with text snoopy78 Vizard 3 07-16-2009 11:23 AM
Create Button or Text Chrissy2009 Vizard 1 07-15-2009 06:34 PM
3d Text with Transparent Borders vjosh Vizard 3 12-01-2004 11:50 AM
