Old 07-13-2009, 02:23 AM
jaylocco jaylocco is offline
Question Making an object to appear after other object done animating
How do I make an object to appear after other object done animating.as example below;
ObjA = viz.add('oA.WRL')
ObjA.setPosition(0,0,0)
ObjA.visible( viz.OFF )
ObjB = viz.add('oB.WRL')
ObjB.setPosition(5,0,0)
PickAction = vizact.sequence(vizact.move(-1,0,0,1),vizact.spin(0,1,0,45,1))
vizact.onpick( objB, objB.runAction, PickAction )
then How do I make visible the objA (objA.visible(viz.ON)) after objB animation is done?
TQ
Old 07-13-2009, 10:47 AM
You can use the vizact.call action to call arbitrary functions. Just change your PickAction to the following:
PickAction = vizact.sequence( vizact.move(-1,0,0,1) , vizact.spin(0,1,0,45,1) , vizact.call(objA.visible,True) )
Old 07-13-2009, 07:17 PM
It works!! thank you..you're the best!!
Making an object flash on and off constantly tomo_the_third Vizard 1 06-23-2009 12:58 PM
reseting an object durf Vizard 3 03-18-2009 12:48 AM
Child Object Rotation paulgoldberg Vizard 5 09-05-2006 12:33 PM
rotate to object jargon Vizard 1 08-08-2005 01:20 PM
