Old 05-11-2009, 10:39 AM
Penguin Penguin is offline
rotating an object
Hi, I want to rotate an object (sphere) similar to the globe in google earth.
The sphere is mapped in front of the main view. With the use of the viz.pick() command I get the intersection position of the mouse pointer on the sphere (intersectionItem.point).
The following code is running in a mouse button down callback function. While dragging the mouse over the sphere the new intersection position is callculated (curIntersectionItem.point)
With this two points and the center of the sphere I get two direction vectors and the angle inbetween.
The rotation of the sphere seems to work until it rolls. Then the mouse movement does not match to the rotation of the sphere any more!
Is there a better way to achieve a stable rotation? While dragging in google earth the same part of the globe always stays under the mouse pointer.
curIntersectionItem = calcUiIntersection()
rotationMat = vizmat.Transform()
rotationMat.makeVecRotVec(vizmat.VectorToPoint(sphere.getPosition(viz.ABS_GLOBAL),intersectionItem.point),vizmat.VectorToPoint(sphere.getPosition(viz.ABS_GLOBAL),curIntersectionItem.point))
spherePos = sphere.getPosition(viz.ABS_GLOBAL)
sphereMat = sphere.getMatrix(viz.ABS_GLOBAL)
sphereMat.setTrans(0,0,0)
transformMat = vizmat.Transform()
transformMat = rotationMat * sphereMat
transformMat.setTrans(spherePos)
sphere.setMatrix(transformMat,viz.ABS_GLOBAL)
intersectionItem = curIntersectionItem
Old 05-11-2009, 05:32 PM
Interesting goal. I whipped up a bit of code that orbits the sphere by telling the sphere to "lookat" the intersection point, then rotating the sphere the initial offset amount.
The code is not quite right yet because sustained clicking on the same point rolls the sphere around that point. Maybe somebody knows whats wrong?
import vizmat
import vizshape
viz.mouse.setOverride(viz.ON)
node = vizshape.addSphere(pos=[0, 1.8, 3])
node.texture(viz.add('image2.jpg'))
rotation = None
def onGrab():
	global rotation
	intersectionItem = viz.pick(1)
	if intersectionItem.valid:
		src_ori = vizmat.Quat(node.getQuat(viz.ABS_GLOBAL))
		node.lookat(intersectionItem.point, viz.ABS_GLOBAL)
		dst_ori = vizmat.Quat(node.getQuat(viz.ABS_GLOBAL))
		#D = O * S so O = D * 1/S
		rotation =  src_ori * dst_ori.inverse()
vizact.onmousedown(viz.MOUSEBUTTON_LEFT, onGrab)
def moveSphere():
	if rotation:
			node.lookat(intersectionItem.point)
			node.setQuat(rotation, viz.ABS_LOCAL)
vizact.onupdate(viz.PRIORITY_DEFAULT, moveSphere)
def endGrab():
	global rotation
	rotation = None
vizact.onmouseup(viz.MOUSEBUTTON_LEFT, endGrab)
Paul Elliott
WorldViz LLC
Old 05-12-2009, 12:21 PM
Except for the slight roll, your code works fine. But here it comes: when I attach the sphere to the main view the rotation doesn't work any longer.
import vizmat
import vizshape
viewLink = viz.link(viz.MainView,node)
viewLink.preTrans([0,0,3])
rotation = None
def onGrab():
	global rotation
def moveSphere():
	if rotation:
def endGrab():
	global rotation
	rotation = None
Old 05-12-2009, 12:29 PM
Righto. The link is overriding the rotation we are giving the sphere. To fix we tell the link to only operate on position
viewLink = viz.link(viz.MainView,node, mask=viz.LINK_POS)
Paul Elliott
WorldViz LLC
Old 05-12-2009, 02:09 PM
Step by step I'm able to locate the source of the problem: I use the sphere in a hierarchical group order. The following code reproduces the strange behaviour of rotating.
import vizmat
import vizshape
root = viz.add(viz.GROUP, parent=viz.WORLD)
root.setPosition([0,1.8,3],viz.REL_GLOBAL)
node = vizshape.addSphere(pos=[0,0,0], parent=root)
rotation = None
def onGrab():
	global rotation
def moveSphere():
	if rotation:
def endGrab():
	global rotation
	rotation = None
Old 05-13-2009, 11:18 AM
Jerry Jerry is offline
Here's another way to do it.
from viz import *
go()
clearcolor(.8,.8,.8)
vert = add('ball.wrl')
vert.translate(0,1.8,2)
xang = 0
yang = 0
INCREMENT = .5
mouse(OFF)
restrictmouse(OFF)
def mousemove(x,y):
	global xang,yang
	state = buttonstate()
	if state == MOUSEBUTTON_LEFT:
		xang = xang + x*INCREMENT
		yang = yang + y*INCREMENT
		vert.rotate(0,1,0,-x*INCREMENT,RELATIVE_WORLD)
		vert.rotate(1,0,0,y*INCREMENT,RELATIVE_WORLD)
mousedata(RELATIVE,RELATIVE)
callback(MOUSEMOVE_EVENT,mousemove)
Old 05-14-2009, 11:50 AM
Of course, of course, the roll parameter =) Thanks for sharing the fix.
Paul Elliott
WorldViz LLC
Old 05-17-2009, 01:47 PM
Since spinning balls is so much fun,
Let's try spinning more than one.
from viz import *
go()
ball1 = add('ball.wrl')
ball1.translate(.3,1.8,1.5)
ball2 = add('ball.wrl')
ball2.translate(-.3,1.8,1.5)
balls = []
balls.append(ball1)
balls.append(ball2)
INCREMENT = .5
mouse(OFF)
restrictmouse(OFF)
def mousemove(x,y):
	object = pick()
	if viz.mouse.getState() == viz.MOUSEBUTTON_LEFT:
		mousedown = 1
		mousedown = 0
	if object in balls and mousedown == 1:
		object.rotate(0,1,0,-x*INCREMENT,RELATIVE_WORLD)
		object.rotate(1,0,0,y*INCREMENT,RELATIVE_WORLD)
Or if you like the number three,
Let's try to make them all agree.
from viz import *
go()
ball1.translate(0,2.1,2)
ball2.translate(.4,1.5,2)
ball3 = add('ball.wrl')
ball3.translate(-.4,1.5,2)
balls = []
balls.append(ball1)
balls.append(ball2)
balls.append(ball3)
INCREMENT = .5
mouse(OFF)
restrictmouse(OFF)
def mousemove(x,y):
	object = pick()
		mousedown = 1
		mousedown = 0
		for b in range(len(balls)):
			balls[b].rotate(0,1,0,-x*INCREMENT,RELATIVE_WORLD)
			balls[b].rotate(1,0,0,y*INCREMENT,RELATIVE_WORLD)
And here's the one you want the most,
Just like iPhone make it coast.
from viz import *
go()
balls = []
balls.append(ball1)
balls.append(ball2)
increment = .5
COAST = 1
mx = 0
my = 0
object = []
spinning = 0
mouse(OFF)
restrictmouse(OFF)
def mousemove(x,y):
	global mx,my,object,spinning,increment
	if spinning == 0:
		object = pick()
	if mouse.getState() == MOUSEBUTTON_LEFT:
		object = pick()
		mousedown = 1
		killtimer(COAST)
		spinning = 0
		mousedown = 0
		object.rotate(0,1,0,-x*increment,RELATIVE_WORLD)
		object.rotate(1,0,0,y*increment,RELATIVE_WORLD)
		mx = x
		my = y
	if mousedown == 1 and spinning == 0:
		increment = .5
		spinning = 1
		starttimer(COAST,.01,FOREVER)
def onTimer(num):
	global spinning,mx,my,object,increment
	if num == COAST:
		object.rotate(0,1,0,-mx*increment,RELATIVE_WORLD)
		object.rotate(1,0,0,my*increment,RELATIVE_WORLD)
		increment = increment - .01
		if abs(increment) < .01:
			spinning = 0
			increment = .5
			killtimer(COAST)
viz.callback(viz.TIMER_EVENT,onTimer)
Old 05-18-2009, 06:24 PM
Spinning is fun
I do agree.
But rotations be done,
I'm going crazy.
Paul Elliott
WorldViz LLC
reseting an object durf Vizard 3 03-18-2009 12:48 AM
Object rotating around world axis, not own axis tacbob Vizard 1 02-15-2007 10:12 AM
Child Object Rotation paulgoldberg Vizard 5 09-05-2006 12:33 PM
rotate to object jargon Vizard 1 08-08-2005 01:20 PM
