Old 04-08-2009, 01:14 PM
durf durf is offline
stopping ontimer
My program runs on onkeydown() that are assigned to different def func:. When i switch from func A to func B. A is still running. The reason is I think is becuase of the ontimers that I have associated with it. So is there anyway to stop and ontimer? Any other suggestions to handle this problem?
def funcA():
  def calculate():
  #CODE
  vizact.ontimer2(0,viz.FOREVER,calculate)
vizact.onkeydown('a',funcA)
def funcB():
  def speed():
  #CODE
  vizact.ontimer2(0,viz.FOREVER,speed)
vizact.onkeydown('b',funcB)
Old 04-09-2009, 12:03 PM
You could try this to keep only one timer active at a time.
def calculate():
      print 'calculate'
def speed():
      print 'speed'
timer1 = vizact.ontimer2(1,viz.FOREVER,calculate)
timer2 = vizact.ontimer2(1,viz.FOREVER,speed)
timer1.setEnabled(viz.OFF)
timer2.setEnabled(viz.OFF)
def funcA():
  timer1.setEnabled(viz.ON)
def funcB():
  timer2.setEnabled(viz.ON)
Old 04-11-2009, 11:06 AM
Is there a way to use the same key to turn on and turn off the same function?
IE. If I hit 'a' to enable def calculate() then I hit 'a' again to disable def calculate().
I have the idea I think for it. Which would be to have a bool value and then change it from true to false and have if else statements to check it. Could be wrong thats why Im asking.
Old 04-11-2009, 07:50 PM
You could use viz.TOGGLE so that each time you press the key the timer will change states and your function will either start or stop being called
def funcA():
  timer1.setEnabled(viz.TOGGLE)
def funcB():
  timer2.setEnabled(viz.TOGGLE)
Old 06-02-2009, 12:38 PM
yak yak is offline
i have an application where i have my 3d human model walking but i want it to freeze...or pause how can i do that.
stopping a function durf Vizard 1 03-31-2009 05:45 PM
stopping a goto() vsully Vizard 1 01-24-2006 02:43 PM
partially stopping tracking vsully Vizard 1 01-12-2005 10:02 AM
