Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 08-29-2008, 08:40 AM
Elittdogg Elittdogg is offline
String within a string problem?
I'm sure this is very basic, but for whatever reason I'm unable to wrap my head around it. I'm using python based code only.
x=raw_input("Enter something for x or enter 'quit' to exit the program: ")
y=raw_input("Enter a choice (#, a, or b): ")
if x == 'quit':
    print 'Done.  Thank you.'
    print y
if y.isdigit():
    print x[y]
and this is what happens:
Enter something for x or enter 'quit' to exit the program: hello
Enter a choice (#, a, or b): 2
2
File "C:/Python25/homework 1 Littman.py", line 10, in <module>
print x[y]
TypeError: string indices must be integers
What should come up is l. I need to be able to specify which place in the string the number corresponds to. For instance, (and this works) if I set x='monkey' and y=2. Then I print x[y] I get n. Why doesn't it work when I enter in 2 into the prompt???
So my 3 choices are a number, a or b. If it's a number then I need to output the correct letter from the string (but of course it can't exceed the length of the string). If I enter a, I need to output the length of the string (so hello would be 5 (I also need to start counting from 1, not 0). And if I enter b I need to output the initial string in all CAPS (so I'd need hello to be HELLO). Right now I can't get past the integer and I don't know why.
Old 08-29-2008, 01:35 PM
The raw_input function returns a string object, which cannot be used as an index in a list. You will need to convert the string to an integer first:
index = int(y)
print x[index]
export problem bazelaisr Vizard 2 05-28-2008 10:19 AM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
sound problem alaa Vizard 7 09-02-2005 01:13 PM
problem with input boxes shai Vizard 6 08-15-2005 10:51 AM
