Old 04-07-2011, 03:22 PM
nige777 nige777 is offline
Speech
Thought I'd give speech recognition a whirl, so after installing pywin32 I navigate to the makepy script in the Viz 4 site-packages but all I get is an error message thus:
C:\Program Files\WorldViz\Vizard4\bin\lib\site-packages\win32com\__init__.py:89: ImportWarning: Not importing directory 'C:\Program Files\WorldViz\Vizard4\bin\lib\site-packages\win32com\gen_py': missing __init__.py
  import win32com.gen_py
  File "<string>", line 11, in <module>
  File "C:\Program Files\WorldViz\Vizard4\bin\lib\site-packages\win32com\client\makepy.py", line 70, in <module>
    from win32com.client import genpy, selecttlb, gencache
  File "C:\Program Files\WorldViz\Vizard4\bin\lib\site-packages\win32com\client\__init__.py", line 11, in <module>
    import gencache
  File "C:\Program Files\WorldViz\Vizard4\bin\lib\site-packages\win32com\client\gencache.py", line 662, in <module>
    __init__()
  File "C:\Program Files\WorldViz\Vizard4\bin\lib\site-packages\win32com\client\gencache.py", line 58, in __init__
    Rebuild()
  File "C:\Program Files\WorldViz\Vizard4\bin\lib\site-packages\win32com\client\gencache.py", line 649, in Rebuild
    _SaveDicts()
  File "C:\Program Files\WorldViz\Vizard4\bin\lib\site-packages\win32com\client\gencache.py", line 65, in _SaveDicts
    f = open(os.path.join(GetGeneratePath(), "dicts.dat"), "wb")
  File "C:\Program Files\WorldViz\Vizard4\bin\lib\site-packages\win32com\client\gencache.py", line 141, in GetGeneratePath
    f = open(fname,"w")
IOError: [Errno 13] Permission denied: 'C:\\Program Files\\WorldViz\\Vizard4\\bin\\lib\\site-packages\\win32com\\gen_py\\__init__.py'
Would be nice to be able to start moving my work over to 4, but am a bit stuck because I also use other automation objects via makepy, so its quite a biggy for me.
Any ideas whats going on from that error message?
Old 04-07-2011, 03:31 PM
You probably don't have write permissions for that folder. Try running the makepy script using admin privileges.
Old 04-08-2011, 05:17 AM
Ok, well managed to get makepy to run through the Viz 4 interactive prompt (is this a valid method of doing this?) using this code:-
import win32com.client.makepy
win32com.client.makepy.ShowInfo("")
- select the MS Speech object from the list and it spits out this
Microsoft Speech Object Library
 {C866CA3A-32F7-11D2-9602-00C04F8EE628}, lcid=0, major=5, minor=4
 >>> # Use these commands in Python code to auto generate .py support
 >>> from win32com.client import gencache
 >>> gencache.EnsureModule('{C866CA3A-32F7-11D2-9602-00C04F8EE628}', 0, 5, 4)
However when I then run the speech.py script I get this error message-
  File "C:\Users\APD\Documents\Nige_PHD\Vizard_Python Development\speek.py", line 56, in <module>
    class ContextEvents(win32com.client.getevents("SAPI.SpSharedRecoContext")):
TypeError: Error when calling the metaclass bases
    cannot create 'NoneType' instances
Any ideas?? Am I doing something wrong I got it to work in Viz3 with very little problem.
Old 04-08-2011, 05:51 AM
Interestingly I have just managed to manipulate the IFCsvr activeX object with no problems - however I am using this within my code-
gencache.EnsureModule('{B2173F4D-1371-4649-8554-310D6DC1734F}', 0, 1, 4)
I've noticed this method is different to what's being used in the Speek script (as it is presented in the knowledgebase article), what am I doing wrong can anyone tell?
Old 08-25-2012, 11:46 AM
gribbers gribbers is offline
nige777,
Did you ever get to the bottom of this? I only ask because I'm having the same problem even though I'm logged in as 'Administrator'.
Thanks.
Old 09-04-2012, 02:42 AM
Ignore my previous post. Simple permissions problem. How embarrassing!
Viz speech cutting off early Enlil Vizard 7 01-27-2016 05:41 AM
Speech Bubbles jassel41 Vizard 0 11-30-2009 11:12 PM
Avatar finish speech ? djdesmangles Vizard 2 02-15-2008 07:56 AM
Speech Recognition Johannes Vizard 1 05-16-2005 11:46 AM
