Old 04-16-2008, 12:50 PM
joeymax joeymax is offline
collision with physics enabled
Hi there, I have created a simple scene with physics enabled. In my scene I have a few objects; ball.wrl, blueglass.osg, greenwalls.osg
What I want to do is apply some sort of collision to the scene, so that I am able to walk through ‘blueglass’, but not through ‘greenwall’.
The ‘ball’ object translates with the viewpoint, so it goes wherever I go, that way, when I walk through the blueglass object in the scene, the ball collides with blueglass and triggers an event (in this case it simply prints a message).
I have not been able to find a way to apply collision to ‘greenwall’ to stop me from walking through it – while physics are enabled.
Any help would be much appreciated
viz.phys.enable()
theview = viz.get(viz.MAIN_VIEWPOINT)
theview.translate(0,1.4,0)
greenwall = viz.add('greenwall.osg')
blueglass = viz.add('blueglass.osg')
ball = viz.add('ball.wrl')
ball.setScale(0.1,0.1,0.1)
ball_Link = viz.link(theview,ball)
ball_Link.preTrans([0,0,2])
greenwall.collideMesh()
greenwall.disable(viz.DYNAMICS)
greenwall.enable(viz.COLLIDE_NOTIFY)
ball.collideMesh()
ball.disable(viz.DYNAMICS)
ball.enable(viz.COLLIDE_NOTIFY)
blueglass.collideMesh()
blueglass.disable(viz.DYNAMICS)
blueglass.enable(viz.COLLIDE_NOTIFY)
MOVE_SPEED = 5
TURN_SPEED = 70
def onCollideBegin(e):
	if e.obj1 == ball and e.obj2 == greenwall:
		print 'ball has hit greenwall'
	if e.obj1 == ball and e.obj2 == blueglass:
		print 'ball has hit blueglass'
def mytimer(num):
	if viz.iskeydown(viz.KEY_UP):
		theview.move(0,0,MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
	elif viz.iskeydown(viz.KEY_DOWN):
		theview.move(0,0,-MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
	if viz.iskeydown(viz.KEY_RIGHT):
		theview.rotate(0,1,0,TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE_WORLD)
		theview.rotate(0,1,0,-TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE_WORLD)
viz.callback(viz.COLLIDE_BEGIN_EVENT,onCollideBegin)
viz.clearcolor(viz.WHITE)
Old 04-17-2008, 02:33 PM
You can enabled viewpoint collision detection by using the following code:
viz.collision(1)
If you don't want the viewpoint to collide with the blueglass, then add the following line as well:
blueglass.disable(viz.INTERSECTION)
Also, I noticed that you set the eyeheight to 10000 in the script stage settings. You should set it to a smaller value like 1.8.
Old 04-17-2008, 02:49 PM
thankyou so much! thats really helped me out.
works perfect
physics engine exception ad_astra Vizard 3 03-25-2009 11:31 AM
Collision detection with haptic pen mjabon Vizard 3 01-17-2008 06:35 PM
Collision between two meshes? v-Salik Vizard 1 12-07-2007 09:31 AM
Collision with avatars and scene not working JvdBosch Vizard 12 09-14-2006 06:01 PM
collision events trigger Eunice Vizard 1 01-03-2006 10:39 AM
