Old 02-28-2008, 03:48 AM
Robbos Robbos is offline
Question On click Sound Play Problems
Hi i am also a university student on the same project as "Psirus" (who recently joined) and have run into a problem similar to his but cannot seem to find the solution within the help he was given.
I wish to make a set of spheres all emit sound but the sound be muted until they are clicked and effectively "activated"
I have managed to get an error message on click (which means my onpick command is obviously working (YAY)), and can remove the error message by adding the relevant variable at the end, but the sound does still not play.
Hopefully someone can shed some light.. Heres my code... Thanks in advance
viz.STEREO
#smallballs
sball1 = viz.add('sb1.wrl')
##sball2 = viz.add('sb1.wrl')
##sball3 = viz.add('sb1.wrl')
##sball4 = viz.add('sb1.wrl')
##sball5 = viz.add('sb1.wrl')
##sball6 = viz.add('sb1.wrl')
These are commented out until i can get one working
#making music play when click on a sphere
def soundToggle1(sball1):
sball1.active = not sball1.active
if sball1.active:
sball1.audio.volume(1)
sball1.audio.volume(0)
########active sound on click
sball1.audio = viz.addAudio('sound1.wav',loop=True,volume=0.0)
sball1.active = False
vizact.onpick(sball1,soundToggle1,sball1)
The bit in red is the bit that can remove the error message but does nothing.
Old 02-28-2008, 02:02 PM
You need to post the code using the [code][/code] tags. This will preserve the indentation which is necessary for running Python code.
Sound Looping Problem JMOwens Vizard 4 09-29-2010 09:42 PM
Stuttering sound Jerry Vizard 1 06-13-2007 12:36 PM
Sound in one ear only? Jerry Vizard 1 06-29-2006 04:26 PM
sound problem alaa Vizard 7 09-02-2005 01:13 PM
3D sound in vizard virtmeg Vizard 1 01-10-2005 09:06 AM
