Old 01-17-2008, 08:16 AM
theuberk theuberk is offline
Skydome texture problem
I'm trying to make a skydome for my virtual world, but I'm having a problem with the way the texture is showing up in vizard. I've attached images below to show the dome in both 3ds max and vizard.
Skydome in 3ds Max:
Skydome rendered in 3ds Max:
Skydome in vizard:
It seems that in vizard only half of the texture is actually being rendered on the dome. I've checked to see if it wraps around the other side of the dome and it doesn't. It looks the same on the outside of the dome. I've also tried to double and half the offset/tiling of the texture which had no effect. Any help?
ID:	218   Click image for larger version
ID:	219   Click image for larger version
Old 01-17-2008, 07:30 PM
The OSG exporter does not use the UV coordinates of the material, it only uses the UV coordinates of the mesh. This means you will have to directly modify the UV coordinates of the skydome mesh.
Old 01-18-2008, 06:56 AM
Fixed it with a uvw map modifier. Thanks for the help .
texture mapping problem dellatails Vizard 1 03-12-2006 12:13 PM
problem with female animations vmonkey Vizard 1 10-07-2005 11:36 AM
how I can get my texture to appear exactly as is defined mspusch Vizard 1 04-23-2005 01:12 PM
avatar head texture issues rconrey Vizard 3 11-17-2004 05:05 PM
Texture map rendering problem JRichizzle Vizard 4 03-04-2004 08:20 AM
