Old 06-16-2009, 09:01 PM
cgibb cgibb is offline
Originally Posted by Gladsomebeast View Post
The material type is the button next to the drop down menu. It says multi/sub-object. I should have said multi/sub-object when I said composite in my last post.
The type of the materials in the list are what matter. Looks like they are of type VRayMtl, which only works with Max's off-line renderer. They will not export to OSG format. I think this model was not created with real-time exporting/rendering in mind. The density of the chair mesh in your last screen shot also suggests this model was only intended for off-line rendering.
Don't know if you need this kitchen scene, but I've exported this free kitchen model from TurboSquid successfully:
http://www.turbosquid.com/3d-models/...kitchen/363010
That makes sense. Does that mean just those materials could not be used with Vizard, or could I possibly assign standard materials and export from there?
I did get the kitchen model that you linked working successfully, and we may end up using that one instead.
Thanks again for all your help.
