Old 05-08-2008, 07:24 AM
joeymax joeymax is offline
thanks... I'll try using PNG's
can i simply apply the PNGs to objects in max and still get the transparency, or do i have to apply the PNGs to the model through vizard. if so I guess i still need to apply a uwv map modifier before i export so the texture looks correct?
..is there no way to correct the 'flickering' problem when using standard diffuse/alpha texture?
thanks again
