Old 11-17-2016, 03:23 AM
zumbay zumbay is offline
Yes, of course!
It seems I found the main reason for the frame drop: its the collideMesh() I am adding to the models.
I attached 2 images, showing the render stats for 2 versions of the same environment, once with and once without collideMesh() for each model.
Would be great if there is a way I could still be able to grab, move, and overlap this limited amount of objects.
thanks
ID:	859   Click image for larger version
