Old 09-01-2016, 06:20 AM
It's difficult to say without being able to run code that reproduces the issue. If the display frame rate is stable then it seems like something in the code is causing this. Both of these methods to move the viewpoint work fine in other examples. Are you able to run your code and perhaps simulate treadmill values rather than actually doing any IO operations?
