Seems like a meters - inches problem. I'm not sure whether Vizard uses the metric system, but check the scaling of your object in Sketchup, especially your settings while exporting. Alternatively, you could first scale your object in Vizard to the right proportions. To check whether the scale of your object is 1 meter, import a standard box in Vizard (viz.add('box.wrl')), which is 1 cubic meter if I recall correctly. You can compare the size of your custom objects to that of the box.
