Old 11-22-2013, 12:21 PM
The geometry node names are assigned by the OSG exporter for Max using the material names. The viz.pick command is passing back the name of the lowest level node which is the geometry. If your objects have different materials you can rename the materials so those names show up when you pick the object.
