Old 05-09-2013, 04:45 PM
That's a lot of separate objects to be rendering and animating per frame. Do you actually need each object to be a fully modeled sphere, or is a point sprite acceptable. You can most likely achieve your desired frame rate by rendering all the objects as a single mesh of points, and animated the points within a vertex shader. If you are interested in going along with this method, then I can provide some sample code.
