Old 09-07-2012, 08:50 AM
nabrahamson nabrahamson is offline
So to follow up, I've been able to reproduce the coordinate system in inspector. However, I am now trying to move that screw along one of the axis of that coordinate system by doing the following:
moveaction = vizact.moveTo(y_trans,time = 1.0, mode = viz.ABS_GLOBAL)
screw.addAction(moveaction)
The point y_trans refers to is the endpoint of the green axis in the attached photos. As you can see by the second photo, the screw does not get moved to the end of the green Axis. Is viz.ABS_GLOBAL the wrong mode to use with this command? Or am I just referring to the wrong coordinate system?
ID:	521   Click image for larger version
