Old 05-26-2012, 02:46 PM
vrmdl vrmdl is offline
Swap eye image for one window
Originally Posted by farshizzo View Post
Do you see the discontinuity between the two windows when viewing on a desktop? If so, can you post a screenshot.
Or do you only see the discontinuity when viewing on the actual projected surface of your CAVE? If so, then your projectors might not be properly aligned.
I am currently working on a two wall system which is driven by the same computer and one graphics card. I generated one front image and one floor image.
The screenshot is attached. Is this due to the projector alignment problem?
Thanks.
