Old 07-03-2011, 11:39 PM
hachilab hachilab is offline
Thank you Jeff.
It works for 'spin'.
Infact, I was tring to change the position of an object/avatar.
ground = viz.add('roughground.wrl')
ball = viz.add('ball.wrl')
ball.center(0,1,0)
move = vizact.walkTo([1,ground,1], walkAnim = None, walkSpeed = 0.5)
vizact.onkeydown('1', ball.addAction, move)
I tried to move the ball along a rough surface. However, using above lines, the ball was not "above" but "partially inside" the ground. I tried to set the level of the ball by [1,gound+1,1], but it seems an invalid command. So, I tried to set the "built-in position" by "ball.center(0,1,0)". It doesn't work. Sorry for the confusion.
Best Regards
