Old 05-03-2011, 01:20 PM
You can create a texture with alpha channel so that part of the texture is transparent.
To just make a certain color transparent you could do this with a simple shader. Take a look at the alphaMap example in the docs and the alphaMapper.frag program it uses for some ideas. Also, if you have Vizard 4 installed the shader documentation has been updated and may be helpful.
