Old 03-22-2011, 01:13 PM
Salvar Salvar is offline
Originally Posted by farshizzo View Post
Is the tracker on the HMD 6DOF or 3DOF orientation? Either way, to integrate HMD tracking you should just need to use the <link>.preMultLinkable command. After you have setup the link between the car and the viewpoint, just add the following code:
view_link.preMultLinkable(tracker)
The HMD tracker data should now be applied relative to the car orientation.
Thanks for the response.
I was hoping for the solution to be something simple as this, but it gives me an error saying that the tracker object (added with the command "polhemus = viz.add('polhemus.dle')") is not a linkable.
Is there any way to make it linkable?
