Old 02-01-2007, 07:28 PM
AlyssaK AlyssaK is offline
<multimedia:image>.getSize
Hi everyone,
I'm using the example from the documentation <multimedia:image>.getSize
tex = viz.add('box.wrl')
size = tex.getSize()
print 'The texture is',size[0],'x',size[1]
and i recieve the following error:
File "testing.py", line 8, in ?
AttributeError: 'VizChild' object has no attribute 'getSize'
I must be overlooking something if you can help please post a response. My intention is to make sure that all images are scaled to a certain size.
Thanks, Alyssa.
Old 02-02-2007, 09:30 AM
The getSize() command only works on texture objects. The tex object in your sample code is actually a node3d object, since box.wrl is a VRML file, not an image file.
Old 02-13-2007, 10:02 PM
Is there anyway to get the dimensions of an vrml file's object? My intention is to make sure these are scaled to a certain size.
Thanks, Alyssa
Old 02-14-2007, 09:34 AM
Sure, here is some sample code that gets the bounding box of a vrml object and prints the dimensions:
model = viz.add('model.wrl')
bb = model.getBoundingBox()
print bb.size
