Old 11-19-2003, 04:15 PM
rosanna rosanna is offline
something to add to your docs re: .wav files and lip flapping
Hello. I spent some time last night trying to get a .wav file that I hard recorded to display proper lip flapping using the avatar.loadSpeech command. I had some trouble because I could not find any specifics in terms of what kHz, etc. to save the wave file as. I had a sample .wav file that worked, where as mine did not.
The sample .WAV file that I used to produce the lip flapping in with the audio synch feature of Vizard appears to be:
22kHz, 16-bit, Microsoft 8-bit PCM encoded
After much trial and error, I got my audio file to function properly in Vizard by saving them as Microsoft 8-bit PCM encoded .wav files.
If this is the desired format for .wav files to function properly with the avatar.loadSpeech command in Vizard, I think it should be documented.
thanks!
Rosanna
