Old 09-11-2006, 01:46 PM
pbeeson pbeeson is offline
slow intersect call
I am having serious slowdowns in my Vizard script. I tracked it down to the fact that I am calling viz.intersect 180 times in a single callback. The 180 iteration loop takes around 0.15 seconds to run. This is werid because pressing F4 twicde shows me that the update is only suppossed to be taking 30-100 milliseconds.
Two things: 1) Is the value shown for Updates when the f4 stats are shown actually in MILLI seconds? 2) Is there a faster call than viz.intersect in Vizard 2.53g?
Old 09-11-2006, 02:36 PM
Strange. I was putting the viewpoint inside of an avatar and using that avatar as the body to detect for collisions. I was doing the 180 line intersections because I was simulating a laser range finder which returns distances to objects in a plane. The laser was not inside the mesh of the avatar, but very close to its front. None of the 180 rays ever touched the body enclosing the viewpoint; however, if I make the avatar that the viewpoint is inside of not visible, then this fuction speeds up a bit by a factor of 2 (0.08 seconds). This is weird to me, but I can live with weirdness.
I still think that 0.08 seconds to calculate 180 intersections seems a bit slow, and would like to know if there is a faster way to cast rays and get the locations (or distances) of the intersection points in the world.
Old 09-11-2006, 02:50 PM
1) The values should be in milliseconds.
2) In 2.53 the viz.intersect() command is pretty much your only option. You might be able to speed up the call by disabling collisions with objects that you are not interested in.
object.disable(viz.COLLISION)
Another thing you can do is create very low-res versions of your models. These low-res versions will represent the collision mesh of the high-res models. Then disable collisions on the high-res and disable rendering on the low-res. The viz.intersect() command performs the intersection on each triangle in your model, regardless of the collision shape you defined for it using the collide*() functions.
Vizard 3.0 allows you to use the underlying physics engine to perform intersection tests, which will be optimized for the collision shapes defined for each model. I just did a test with a simple scene, and performing 100 intersections per frame caused the update time to be 25 ms using viz.intersect() and 2.5 ms using the physics line intersect command.
Old 09-11-2006, 02:54 PM
Disabling collisions with the avatar would give you the same result. See my previous post.
Even though the laser line was not inside the mesh of the avatar, it was inside its bounding box. When Vizard is performing intersection tests it will first check if the line intersects with an objects bounding box. If it does, it will proceed to check if the line intersects with each triangle.
Old 09-11-2006, 03:16 PM
I am getting 80ms with just my "indoor" environment, which is pretty simple. Maybe I should try to separate the walls from the ceiling and floor and add them both to vizard since I never care about intersecting with the seiling or floor.
Old 09-11-2006, 07:22 PM
Unless your floor and ceiling contain a lot of triangles, it's probably not going to make much of a difference. But if you want to try it out, you don't need to create separate models for them. Simply specify the name of the floor/ceiling mesh when disabling collisions. Example:
room.disable(viz.COLLISION,'ceiling')
room.disable(viz.COLLISION,'floor')
Also, do these intersections tests need to be performed every frame? If not, you can offload the intersection tests onto a thread that performs them at a lower rate.
Old 09-11-2006, 08:30 PM
I noticed in version 3 that viz.phys.intersectLine() is much faster than viz.intersect(), but viz.phys.intersectLine seems to have some problems:
1) It returns intersections for non-visible objects (object whose visibility is set to off), which is different that viz.intersect()
2) It ignores the viz.disable(viz.COLLISION) command. Is there a way to get it to ignore certain objects?
I can run viz.phys.intersectLine(begin,end,True) to get a list and then check object IDs, but I don't know if there is an easier way (especially considering that if you have many objects, it might be an optimzation to not check for intersections with particular objects at certain times, e.g. if you are casting rays from within an object).
3) As I said earlier, I am casting 180 "rays" from a virtual laser range finder. When I do this, viz.phys.intersectLine() is much faster than viz.intersect() (Even if I set the all flag to True), but viz.phys.intersectLine actually misses some intersections with the closest objects, while viz.intersect() does not. I'll post two picture to illustrate my point.
Old 09-12-2006, 07:25 AM
Pertaining to point 3 from above posting.
Notice that in the left image, some of the rays cast from the "robot" I have in Vizard (shown as a rectangle) go through the wall (white line in grey space). I believe this is a bug in viz.phys.intersectLine()
When I use viz.intersect() instead of viz.phys.intersectLine(), all rays properly intersect the wall (right image).
(These details don't show up well in the thumbnails, but do in the fuill size images.
ID:	121   Click image for larger version
Old 09-12-2006, 10:05 AM
Is there a collision shape defined for the wall, probably with collideMesh()? viz.phys.intersectLine() only intersects with VizPhysicsShapes, not model geometry.
Old 09-12-2006, 12:19 PM
Yes, collidemesh() is used. It's not all the scans, just a few of them.
Old 09-12-2006, 12:22 PM
Do these missed intersections occur near a triangle boundary?
Old 09-12-2006, 02:42 PM
I just fixed this. Setting an object to non-visible will automatically disable physics on it.
I just modified the physics intersectLine/Node commands so that they ignore objects which have physics disabled on them. viz.COLLISION will still only pertain to the old viz.intersect() command.
I know this really doesn't help you now, but we will probably release an update within the next few days.
Old 09-12-2006, 04:00 PM
It doesn't help me even when I get the update. In 2.53, I could have a body that represented the "viewer". That body could be not visible, so that intersect() would not see it, but collidingwith() still did see it. But, I get by with calling phys.intersect(start,end,True) and then removing points that intersect the viewers own "body".
Old 09-12-2006, 04:03 PM
No. The thickness of the "wall" is only 0.01, maybe that has something to do with it. I'll try increasing the thickness, and see if that makes a difference.
Old 09-12-2006, 04:12 PM
So you want an object to be invisible, but still allow phys.intersect to work? Then just disable rendering on the object:
object.disable(viz.RENDERING)
Sorry if I misunderstood your question.
Old 09-12-2006, 04:19 PM
I don't care if it is invisible. All I know is that by doing avatar.visible(viz.OFF), in version 2.53, viz.intersect() would never return an intersection with the avatar, but viz.collidingwith() WOULD work if the avatar collided with antoher obstacle.
Maybe THAT was the bug, and now it is fixed. It's just different.
Old 09-12-2006, 04:26 PM
Correct, that behaviour was a bug. In the next release when an object is set to invisible using the node.visible() command, it will not respond to any intersection queries.
Old 09-12-2006, 04:28 PM
Oddly, increasing the thickness of the wall made more rays NOT intersect the wall, while decreasing the thickness of the wall made more rays intersect the wall. By setting the wall thickness to 0, all rays properly see the wall, and the map I get looks like the right figure (see above thumbnails) which is correct. As I increase the thickness of the wall, more white rays go through the wall in the map I make, showing improper intersections with viz.phys.intersectLine()
Attached is the .wrl file of the environment I am using (I changed it to .txt to get it to upload). If you search and replace 0.01, you can change the thickness of walls. I start at (10.5,1.3,-21.0) with an orientation of 0.0. The rays you see in the left image that go through the wall are at about 12.25, 1.3, -17.5 (the thing in the middle in the picture is an avatar).
Hope this helps.
Old 09-12-2006, 06:52 PM
I can't replicate your problem. I downloaded your model and made the thickness of the wall to 1.0. I then setup a timer that would perform a 180 degree sweep of intersection tests based on the current view position/orientation. I spent a minute navigating through the maze and never got a missed intersection. Here's the script I used to test it out:
import math
wall = viz.add('wall_thick.wrl')
wall.collideMesh()
wall.disable(viz.DYNAMICS)
viz.MainView.translate(10.5,1.3,-21.0)
def SweepIntersection():
	#Get begin point for intersection test
	begin = viz.MainView.getPosition()
	bx = begin[0]
	by = begin[1]
	bz = begin[2]
	#Get point 100 units ahead of viewpoint
	forward = viz.Vector(viz.MainView.getMatrix().getForward(),length=100)
	px = forward[0]
	pz = forward[2]
	for deg in range(-90,90):
		#Rotate ahead point by deg (Assume no pitch/roll)
		rad = viz.radians(deg)
		x = math.cos(rad)*px - math.sin(rad)*pz
		z = math.sin(rad)*px + math.cos(rad)*pz
		#Calculate end point
		ex = bx + x
		ez = bz + z
		#Perform intersection
		info = viz.phys.intersectLine(begin,(ex,by,ez))
		#Check if intersection is not valid
		if not info.valid:
			print 'NO INTERSECTION'
vizact.ontimer(0,SweepIntersection)
Does this problem only occur under certain conditions or is it pretty much random?
Old 09-12-2006, 08:34 PM
Here is code that works with the Test.wrl I posted earlier. The view is at an angle to the hallway, so a line straight ahead should intersect the wall which is 4.3 meters away. But, this particular line misses the intersection with the closest wall and intersects another wall in the environment (> 10 meters away).
This shows the different results sometimes returned by viz.phys.intersectLine() and viz.intersect().
import viz, math
env = viz.add('Test.wrl')
env.collidemesh()
env.disable(viz.DYNAMICS)
start_pos=[10.5, 1.3, -21.43391, 23.975]
view=viz.get(viz.MAIN_VIEWPOINT)
view.translate(start_pos[0], start_pos[1], start_pos[2])
view.rotate(0,1,0,start_pos[3], viz.BODY_ORI,viz.ABSOLUTE)
def dist(x1,y1,x2,y2):
    return math.sqrt(pow(x1-x2,2)+pow(y1-y2,2))
def timerCallback(num):
    end_pos=[start_pos[0]+100*math.sin(start_pos[3]*math.pi/180),
             start_pos[1],
             start_pos[2]+100*math.cos(start_pos[3]*math.pi/180)]
    inters_obj = viz.phys.intersectLine(start_pos[0:3], end_pos)
    print inters_obj.intersectPoint
    print dist(inters_obj.intersectPoint[0],inters_obj.intersectPoint[2],
               start_pos[0],start_pos[2])
    inters_obj = viz.intersect(start_pos[0:3], end_pos)
    print ''
    print '\n\n'
viz.callback(viz.TIMER_EVENT, timerCallback)
viz.starttimer(1, 1, -1)
Old 09-13-2006, 09:33 AM
I see now, at first I thought the problem was that no intersections were being reported, but the problem is that it doesn't return the closest intersection. Thanks for the test script, the problem should be fixed now.
Old 09-13-2006, 09:51 AM
Any way I can get my hands on the fixed code. For "testing" purposes.
