Old 03-24-2021, 10:21 PM
tianmoran tianmoran is offline
Touch Controller Problem
Hi I would like to use the touch controller to control the movement of a scooter.
The ideal scene would be each time I load a road scene and the rider starts accelerating then rides the scooter to the end point at a constant speed. However, I am currently encountering two problems:
1) When I start running the script, only part of the scene can be loaded;
2) It seems the touch button events can not be detected as the text 'done' I inserted can not be printed out.
Can someone help me out with this pls?????
###### Import packages
import sys
import vizconnect
import vizconfig
import vizshape
import viztask
import vizinput
import vizinfo
import time
import random
import oculus
import numpy
import steamvr
import math
from numpy import *
hmd = oculus.Rift()
touch = hmd.getRightTouchController()
##### Parameters
viz.setMultiSample(4)
viz.fov(60)
ini_x =6
ini_y = -4.2
ini_z = -145
os_x = 0
os_y = 0
os_z = -5
ground_x =6
ground_y = -4.2
ground_z = -145
v = [15,25,35]
a = 4.1667
con = 3
trialNo = 15
trial = v * trialNo
##### Set up mainview
viz.MainView.move([ini_x + os_x, ini_y + os_y, ini_z + os_z])
view = viz.MainView
# Setup navigation node and link to main view
navigationNode = viz.addGroup()
viewLink = viz.link(navigationNode, view)
viewLink.preMultLinkable(hmd.getSensor())
# Apply user profile eye height to view
profile = hmd.getProfile()
if profile:
	navigationNode.setPosition([ground_x,ground_y+profile.eyeHeight,ground_z])
	navigationNode.setPosition([ground_x,ground_y+1.8,ground_z])
##### Create skylight
sky_light = viz.addLight(euler=(0,90,0))
sky_light.position(0,0,-1,0)
sky_light.color(viz.WHITE)
sky_light.ambient([0.9,0.9,1])
##### Create sky
sky = viz.add(viz.ENVIRONMENT_MAP,'sky.jpg')
skybox = viz.add('skydome.dlc')
skybox.texture(sky)
# Setup Oculus Rift HMD
if not hmd.getSensor():
	sys.exit('Oculus Rift not detected')
# Check if HMD supports position tracking
supportPositionTracking = hmd.getSensor().getSrcMask() & viz.LINK_POS
if supportPositionTracking:
	# Add camera bounds model
	camera_bounds = hmd.addCameraBounds()
	camera_bounds.visible(False)
	# Change color of bounds to reflect whether position was tracked
	def CheckPositionTracked():
		if hmd.getSensor().getStatus() & oculus.STATUS_POSITION_TRACKED:
			camera_bounds.color(viz.GREEN)
			camera_bounds.color(viz.RED)
	vizact.onupdate(0, CheckPositionTracked)
#viz.setMultiSample(8)
### Import the Scooter model
scooter = viz.add('G:/ScooterProject/ChengZM/ChengZM_res/scooter.dae')
scooter.setPosition([ground_x-0.25,ground_y,ground_z+2.15])
scooter.setEuler([90,0,0])
def UpdateView(m_s,a, up_lim):
	yaw,pitch,roll = viewLink.getEuler()
	m = viz.Matrix.euler(yaw,0,0)
	p = viz.MainView.getPosition()
	dm = m_s + viz.getFrameElapsed() * a
	print('m0', m)
	if dm <= up_lim:			### accelerating
		if p[0] < (ground_x-0.25)+1.5 and p[0] > (ground_x-0.25)-1.5:
			print('InIf')
			if touch.isButtonDown(oculus.BUTTON_INDEX):
				m.preTrans([0,0,dm])
				print('done')
			if touch.isButtonDown(oculus.BUTTON_HAND):
				m.preTrans([0,0,-dm])
		elif p[0] >= (ground_x-0.25)+1.5 or p[0] <= (ground_x-0.25)-1.5:
	else:			### constant speed movement
				m.preTrans([0,0,up_lim])
				m.preTrans([0,0,-up_lim])
	navigationNode.setPosition(m.getPosition(), viz.REL_PARENT)
	scooter.setPosition(m.getPosition(), viz.REL_PARENT)
	return p, dm
def sta_timer():
	for i in range(3):
		timer_3D = viz.addText3D(str(i),pos=[ground_x,ground_y+profile.eyeHeight,ground_z+20])
		timer_3D.fontSize(10)
		timer_3D.resolution(1)
		yield viztask.waitTime(1)
		timer_3D.visible(viz.OFF)
def Sct_dis():
	#viz.collision(viz.ON)
	##### Experiment starts
	##### Randomize trials
	random.shuffle(trial)
	for i in range(len(trial)):
		for j in range(2):
			yield viz.waitTime(1)
			### Import the road model
			if j == 0:				### the first part in this trial
				road_model =  viz.add('G:/ScooterProject/ChengZM/ChengZM_res/RoadTY-only.dae')   ########## should be the reference road
				road_model.setEuler([90,0,0])
				road_model.setPosition([0,-5,-5])
			elif j == 1:			### the second part in this trial
				road_model =  viz.add('G:/ScooterProject/ChengZM/ChengZM_res/RoadTY-only.dae')   ########## should be the free road
			yield viz.waitTime(2)
			### Setup arrow key navigation
			up_lim = trial[i]
			m_s = 0.01
			### Exp starts
			sta_timer()
			final_p = 0
			timer1 = vizact.ontimer(0,UpdateView(m_s, a, up_lim))
			while final_p < 30:
				startTime = viz.tick()
				timer1.setEnabled(viz.ON)
				pp, ss = UpdateView(m_s, a, up_lim)
				final_p = pp[2]
				final_s = ss
			timer1.setEnabled(viz.OFF)
			yield viz.waitTime(3)
			### data record
		#viz.OFF()
	viz.quit()
viztask.schedule(Sct_dis())
Old 08-25-2021, 10:03 AM
mspusch mspusch is offline
Dear tianmoran,
I believe you received support for this question in the WorldViz Ticked Based support system for customers with support contracts, right?
Please let us know if this is still an open issue,
thanks and all best,
Matthias
pretrans, scene load, touch controller
Oculus Rift Touch Controller Buttons iamnoone87 Vizard 1 06-21-2019 06:26 AM
steamvr controller for htc vive unresponsive zumbay Vizard 2 05-25-2018 11:02 PM
Oculus Rift DK2 + gamepad controller rdkirkden Vizard 4 07-17-2017 02:27 AM
Touch functionality Joran Vizard 4 04-25-2012 08:51 AM
