Old 09-21-2017, 07:48 AM
ganesh93 ganesh93 is offline
Stereoscopic VR Panorama
We have a newly acquired Vuze Stereoscopic VR Camera and would like to port the videos into Vizard for one of our experiments. I saw a script on the forum to do something similar for non-stereo panoramic video projected onto a spherical background.
Any ideas on how to do this for stereo panorama.
Also, the left and right eye video is all encoded in the same mp4, I believe. I did not see separate files for the two channels.
Ganesh
Old 09-24-2017, 10:36 PM
I'm not sure if there is a built-in way with a single video file, I'll check and get back to you. If not, it maybe necessary to create two separate videos from the one video. Then apply each video to its own sphere that's rendered to only one eye. In this case, modify the code here to use two spheres and then add the code below:
sphereLeft.disable(viz.RENDER_RIGHT)
sphereRight.disable(viz.RENDER_LEFT)
Old 09-25-2017, 09:11 AM
Thank you. I found out how to render a left and right channel through their software and problem solved.
Ganesh
Positional Tracking in Stereoscopic Panorama's in Oculus HMD Seadna Vizard 2 12-16-2015 01:05 AM
360 panorama sonika Vizard 8 11-12-2015 02:25 PM
Oculus Rift and 360 Panorama with Vizard Lite Edition mshukun Vizard 4 11-10-2015 11:17 AM
Export 360 panorama image with place marks mshukun Vizard 0 04-24-2013 10:20 AM
360 panorama image cube using as darts target and record the xy coordinates mshukun Vizard 2 03-14-2013 06:17 AM
