Old 07-31-2017, 06:55 PM
Yoshino Yoshino is offline
Question How to use fbx files without animation.
Hello, all.
The goal is to move a 3D model of hand based on the data measured with Mo - cap.
The hand model in the Vizard has confirmed accurate operation, but I need a more accurate hand model.
So, I created a 3D model of hand using blender, made a rig and exported it as an fbx format file.
However, there are some empty nodes in the inspector on Vizard, and an error occurs when getBone.
(AttributeError: 'VizChild' object has no attribute 'getBone')
Please let me know the solution.
Hope to hear from you soon.
ID:	949   Click image for larger version
Old 08-03-2017, 05:17 AM
Currently, the only workflow for creating a hand model with bones and deformable mesh for Vizard would be to export a Cal3D model from 3ds Max.
Old 08-06-2017, 01:15 AM
Thank you for the response.
I introduced the MAX 2015 & 2016 Cal3D Exporters plug-in to 3ds MAX.
(from: http://imvu-customer-sandbox.com/sho...cts_id=5395841)
Which extension should I choose?
I tried export as XAF, MXF XOF,XRF,XAF.But Vizard cannot read these files.
Do I need to set something when exporting?
Old 08-11-2017, 09:27 PM
See the following tutorial for exporting to Cal3D:
http://docs.worldviz.com/vizard/#cal3d_introduction.htm
Use the version of the Cal3D exporter on our website:
http://www.worldviz.com/virtual-reality-software-tools/
Road Animation Path vserchi Vizard 4 11-12-2015 09:29 AM
control animation on ive or wrl files? Darkmax Vizard 8 07-17-2012 12:13 PM
Builtin animation on ive,osg files Chapre Vizard 1 09-08-2011 04:50 PM
