Old 06-12-2017, 07:26 AM
mattyi mattyi is offline
Registered User
Number Pad input
Hi all,
I'm hoping that someone knows how to get vizact.onkeydown to recognize a number pad input. For example, if I enter:
vizact.onkeydown('0',myFunction)
Vizard will recognize the 0 above the letters on my keyboard, but not the 0 on the number pad. What do I use to get it to recognize the characters from that source?
I ask because I've created a simple response time task using vizard which tracks the workload of subjects in a behavioral study. There is limited space in the environment where the study is being run, and a small USB number pad is a pretty good input device that takes up very little space.
Old 06-13-2017, 10:02 PM
Try using key codes instead of numbers to get the number pad key events:
def printKey(key):
	print key
vizact.onkeydown(viz.KEY_KP_0,printKey,'KP_0')
vizact.onkeydown(viz.KEY_KP_1,printKey,'KP_1')
vizact.onkeydown(viz.KEY_KP_2,printKey,'KP_2')
vizact.onkeydown(viz.KEY_KP_3,printKey,'KP_3')
Regarding Flystick2 not detected in Vizconnect as an input rajnishv Vizard 2 11-28-2016 03:08 AM
Blindfolding screen, asking for input, unblindfolding. saajaja Vizard 5 11-14-2013 08:08 AM
does vizard handle input differently when it's embedded? Adam.Grey Vizard 3 06-28-2012 09:07 AM
problem with input boxes shai Vizard 6 08-15-2005 10:51 AM
