Old 11-02-2016, 08:12 AM
VizMars VizMars is offline
Timing problem
Hi!
Please find attached a part of my code.
I use a EyeLink 1000 and so "el" stands for eyelink and represents the eyetracker object [el = pylink.EyeLink()]. The variable "ball" is a .osgb-file with a size of 25mb.
The function do_trial is called every trial in my experiment. I want the sound to be played 2 seconds after the ball appeared. But in the first trial of each block (and only in the first) the ball appears after the sound is played, otherwise it works just fine.
Does anybody know why this happens?
def el_rec_thread():
	while True:
		#check recording status
		error = el.isRecording()  # First check if recording is aborted
		if error != 0:
			end_el_trial()
			return error
		if inspect_over:
			end_el_trial()
			break
		#check if break pressed
		if(el.breakPressed()):	# Checks for program termination or ALT-F4 or CTRL-C keys
			end_el_trial()
			return pl.ABORT_EXPT
def end_el_recording(participant_id, block_num, trial):
	global inspect_over
	sound.play()
	optitrack.set_phase(POST_SOUND)
	msg_end = "%s Block %d Trial %d Ende %d" % ( participant_id, block_num, trial, int(round(viz.tick()*1000)) )
	el.sendMessage(msg_end)
	inspect_over = True
def end_el_trial():
	'''Ends recording: adds 100 msec of data to catch final events'''
	pl.endRealTimeMode()
	pl.pumpDelay(100)
	el.stopRecording()
	while el.getkey() :
		pass
def do_trial(participant_id, block_num, trial, scale, distance):
	global inspect_over
	inspect_over = False
	answer = -1 # set initial value to -1
	#optitrack.set_block(block_num)
	#optitrack.set_trial(trial)
	#This supplies the title of the current trial at the bottom of the eyetracker display
	msg_rec_status = "record_status_message 'Block %d, Trial %d/%d'" % (block_num, trial, N_TRIALS_EXC if (block_num == 0) else N_TRIALS_EXP)
	el.sendCommand(msg_rec_status)
	#defines the trial variables
	#MUST be sent to the EyeLink data file PRIOR TO the Trial Start message ("TRIALID ...")
	msg_trial_var = "TRIAL_VAR_LABELS %s %s %s" % ("Participant_ID", "Block_number", "Trial")
	el.sendMessage(msg_trial_var)
	#Always send a TRIALID message before starting to record.
	#EyeLink Data Viewer defines the start of a trial by the TRIALID message.
	#This message is different than the start of recording message START that is logged when the trial recording begins.
	#The Data viewer will not parse any messages, events, or samples, that exist in the data file prior to this message.
	msg_trial_id = "TRIALID %s Block %d Trial %d" % (participant_id, block_num, trial)
	el.sendMessage(msg_trial_id)
#	#Does drift correction and handles the re-do camera setup situations
#	drift_target.visible(viz.ON)
#	yield viztask.waitFrame(1) #wait for the next frame to be drawn
#	while True:
#		#Checks whether we are still connected to the tracker
#		if not el.isConnected():
#			viztask.returnValue(pl.ABORT_EXPT)
#		try:
#			error = el.doDriftCorrect(MONITOR_WIDTH // 2, MONITOR_HEIGHT // 2, 0, 0)
#			if error == 0:
#				break # if drift correction OK go on
#		except: # if re-calibration is necessary
#			pl.openGraphics( (MONITOR_WIDTH, MONITOR_HEIGHT), 32 )
#			el.doTrackerSetup()
#			pl.closeGraphics()
#			break
#	drift_target.visible(viz.OFF)
	#switch tracker to ide and give it time to complete mode switch
	el.setOfflineMode()
	pl.msecDelay(50)
	#send trial variable data sometime in BETWEEN the TRIALID and TRIAL_RESULT messages
	msg_trial_data = "!V TRIAL_VAR_DATA %s %d %d" % (participant_id, block_num, trial)
	el.sendMessage(msg_trial_data)
	##start recording samples and events to edf file and over the link.
	#error = el.startRecording(1, 1, 1, 1)
	error = el.startRecording(1, 1, 0, 0)
	if(error != 0):	viztask.returnValue(error)
	#disable python garbage collection to avoid delays
	gc.disable()
	#begin the realtime mode
	pl.beginRealTimeMode(100)
	eye_used = el.eyeAvailable() #determine which eye(s) are available
	if eye_used == BINOCULAR:
		el.sendMessage("EYE_USED: 2 BOTH")
		print ("Error, not both eyes used!")
		viztask.returnValue(pl.TRIAL_ERROR)
	ball.setPosition( [0, 0, -distance] )
	ball.setScale( [scale]*3 )
	#determine trial start time
	startTime = viz.tick()
	ball.visible(viz.ON)
	#determine delay of the actual stimulus onset
	drawTime = int( round((viz.tick() - startTime) * 1000) )
	msg_start = "%s Block %d Trial %d Start %d" % ( participant_id, block_num, trial, int(round(viz.tick()*1000)) )
	el.sendMessage(msg_start)
	el.sendMessage("SYNCTIME %d" %drawTime)
	#reset keys and buttons on tracker
	el.flushKeybuttons(0)
	vizact.ontimer2(2, 0, end_el_recording, participant_id, block_num, trial) # repeats = Number of times to repeat the timer. If 0, the timer will be called only once
	rec_data = yield viztask.waitDirector(el_rec_thread)
	if rec_data.returnValue != None: # if not trial-over-case
		viztask.returnValue(rec_data.returnValue)
	#the call to the getRecordingStatus() method makes sure that
	#no Abort menu operations remain to be performed, and generates the trial return code
	ret_value = el.getRecordingStatus()
	###### etc ...
Old 11-02-2016, 01:06 PM
It's a bit difficult to debug without being able to run the script and reproduce the issue. Please see the guidelines for posting Vizard code as this will make it easier for others to help debug.
One thing you could try is to replace:
with a viztask.waitTime() command that yields for 2 seconds and then calls the function. This will prevent later lines of code in the task function from executing until the two seconds has elapsed.
Old 11-04-2016, 11:54 AM
Sorry, but I don't know how to provide a code that reproduces the issues without including the eyetracker commands. I excluded the other parts of the code because these are mainly functions that are used for the communication with the eyetracker.
Does
prevent later lines of code in the task function from executing until the timer expires? That poblem is that I need the el_rec_thread to check if the recording is aborted and for (EyeLink) program termination. If I use
yield viztask.waitTime(2)
then it seems impossible for me to implement this recording thread.
Old 11-08-2016, 10:30 AM
Is there an event or function that can tell me whether the rendering of the world is finished?
rendering, timer
Vizard problem mizutani_jun Vizard 4 01-09-2011 03:39 PM
winviz.exe problem llqqff Vizard 2 07-16-2010 09:08 AM
PPT causing height problem just alex Precision Position Tracker (PPT) 2 01-30-2009 09:50 AM
export problem bazelaisr Vizard 2 05-28-2008 10:19 AM
