Old 11-12-2015, 02:14 AM
Seadna Seadna is offline
Point Cloud Dissapearing
I have loaded a point cloud into Vizard (3DC format renamed from PTS format).
I can only see the point cloud when it is off to one side if i look directly at it then it disappears. Is it a limitation on how many points can be rendered or a memory issue perhaps? I am running a laptop with an i7 and 16gb ram.
Any help much appreciated.
Old 11-12-2015, 12:24 PM
How large is the file?
Does this happen when you view the model in Inspector?
Old 11-16-2015, 02:47 AM
I figured out the issue. I added a clipping plane which seems to have solved the issue.
3dc, disappearing, memory, point cloud, pts
Viewing mesh/point cloud in vizard ecatcom1 Vizard 1 01-20-2015 06:31 AM
Point cloud library agrima Vizard 0 07-05-2014 11:57 PM
animate an object using 5dt data glove 5 ultra agrima Vizard 3 07-01-2014 12:17 PM
Point Clouds martinsantiago Vizard 2 12-13-2013 09:32 AM
looking at a point vadrian Vizard 5 06-07-2005 06:43 PM
