how to record data at fixed rate with viz.starttimer
HI,
I use viz.starttimer(0,1/30,viz.FOREVER) to run my object animation and record the motion data in function myAnimation. But the data is not recorded at 30Hz. instead it is recorded at about 40Hz and fluctuates. viz.callback(viz.TIMER_EVENT,myAnimation) viz.starttimer(0,1/30,viz.FOREVER) I use Oculus DK2. If my virtual scene is complex and the computing burden is high, the data recording rate drops. So I set it at 1/30, and want to have a fixed recording rate. But it doesn't work. Thanks. |
The script updates every frame: if the framerate drops below 30fps, the recording rate will also suffer.
You can decouple this by using the viz.director to start the data recording in a whole new thread, but it will be time asynchronous from the main thread so be careful. Cheers! |
Similar Threads | ||||
Vsync prevents using fresh motion capture data in physics simulations? | performlabrit | Vizard | 2 | 11-05-2013 10:48 AM |
Physics engine update rate and display rate | zharuViz | Vizard | 12 | 10-28-2013 06:52 AM |
Frame rate issue | kopper | Vizard | 2 | 06-09-2013 10:53 AM |
Use saved text file data as replay sources problem | mizutani_jun | Vizard | 4 | 10-14-2010 04:49 PM |
record and playback head-tracked data | michaelrepucci | Vizard | 3 | 11-25-2008 04:20 PM |
