Old 06-17-2015, 12:47 AM
green951 green951 is offline
Registered User
oculus DK2 in vizard 5
I have a problem running oculus DK2 in vizard 5. We also use Vicon tracker to keep track the position of the oculus at the same time. The problem description in vizard is:
'[SensorStateReader] Prediction interval too high: 0.111824 s, clamping at 0.100000 s’
And the first number in seconds can be different at different times (but always > 0.100). The second number in seconds is always the same.
When the problem happens, the orientation updating does not work at that very moment. The problem happens from time to time. So to the viewer, the orientation of the graphics got changed all of a sudden at times. I did not have such problem at the very beginning when I started to use oculus DK2 in vizard. The problem comes up more and more often as time goes.
Anybody here has clues what the problem is and how could be the solution?
Thanks a lot!
Old 06-18-2015, 08:12 AM
mape2k mape2k is offline
Hi there,
I just came here to report the same issue! Are you using a USB extension cable? Because we get the error only when we use our 15 meter extension cable. Without it, the error does not come up! The error will also happen in the demo scene of the DK2, so I am assuming that it is not a Vizard specific error.
Enabling or disabling the Vicon tracker does not seem to have an effect.
Cheers,
Johannes
Vizard 4 Oculus Rift support? NIgroupOS Vizard 1 03-09-2015 03:43 AM
Oculus DK1 and DK2 in Vizard 5 Jeff Vizard 3 10-02-2014 11:00 AM
