Old 06-02-2015, 08:34 AM
gerardo697 gerardo697 is offline
Bird Eye View of Multi-Story Building
Does anyone know how to get a bird-eye view of a multi-story building? Specifically, is there a way to get a bird-eye view of each floor, and have that view change once I have gone from one story to another one?
Old 06-02-2015, 03:53 PM
Take a look at the windows and views tutorial.
Old 06-03-2015, 07:32 AM
Thanks Jeff
Old 06-03-2015, 09:58 AM
That tutorial works, but it can only see the roof top of a building. Would I have to use a while loop so that the bird-eye view that is being displayed will modify to show each different floor plan based on the "z" value that is returned by .getPosition()?
Old 06-03-2015, 01:33 PM
You'll need to change the viewpoint height each time you want to show a different floor. I don't understand the question about the while loop.
Old 06-03-2015, 02:03 PM
I have created a 3 story building on Vizard. When I am on the first floor I would like the bird view window to display the floor plan for that floor. However, if I were to move to the second floor I would want the bird view window to change and show the floor plan for that floor. Is this something that I can do by using a while loop within "UpdateViews()"? Is there a better way to approach this problem?
Old 06-04-2015, 08:24 AM
I was able to get the Bird view to change based on the z-value.
UpperRightWindow = viz.addWindow(pos = (0.8,1.0), size = (0.2,0.25))
UpperRightWindow.visible(0, viz.SCREEN)
BirdView = viz.addView()
UpperRightWindow.setView(BirdView)
def UpdateBirdView():
x,z,y = viz.MainView.getPosition()
if (z >= 0 and z < ceiling):
BirdView.setPosition([x,ceiling,y])
elif ( z >= ceiling and z < ceiling2):
BirdView.setPosition([x,ceiling2,y])
BirdView.setPosition([x,ceiling3,y])
BirdView.setEuler([0,90,0])
UpperRightWindow.fov(120)
vizact.ontimer(0,UpdateBirdView)
The problem I have encountered is that I only see a small part of the building since the x and y values correspond to the center of the building. What can I do in order to show the entire floor of the building?
Create my own view alberto_redo Vizard 1 10-19-2010 12:16 PM
View nlfrnassimi Vizard 4 03-12-2009 06:25 AM
problem with stereo mode shivanangel Vizard 3 10-17-2006 10:58 AM
