Old 05-27-2015, 07:31 PM
jizh1000 jizh1000 is offline
How to set the viewpoint as the proximity target in a Vizconnect configuration?
In the vizard documentation, there is a way for setting the main view as the proximity target:
target = vizproximity.Target(viz.MainView)
But it does not work in the script generated by Vizconnect. I wonder if it is possible to set the viewpoint as the proximity target using Vizconnect?
Thanks.
Old 06-01-2015, 11:18 AM
Use the following to get a handle to a node3D object that has the same transform as the viewpoint:
viewTransform = vizconnect.getDisplay().getNode3d()
target = vizproximity.Target(viewTransform)
This is a linkable object that provides position and orientation but it's not a direct handle to the viewpoint. So it can't be used to set the viewpoint position.
Proximity Sensing Using Kinect JamesCakes Vizard 6 06-24-2016 05:52 AM
Orientation selective (Viewing Vector) Proximity Sensor lmGehrke Vizard 2 03-17-2015 12:31 PM
vizproximity hint - debug 2D areas related to a source only after adding a target! fordprefect Vizard 1 12-15-2014 12:37 PM
Avatar w/ hat cannot look at viewpoint TrashcanPatrol Vizard 5 08-19-2008 08:26 AM
